10-26-2022 02:59 PM
Honest, I've looked in both the printed manual and the pdf version, and I can't find the answer.
In the picture styles settings for the user defined styles, there is a setting for "sharpness" but it doesn't allow any changes. Am I missing something, and if it's not to be modified then why even put it in the settings menu?
I'm new to this camera, but come from years of using the 1D series bodys so I do know my way around most of the menus.
And seriously, if I've missed it, please point me to the page or paragragh or archived scroll that it's explained in.
Thanks for listening!
10-27-2022 05:58 PM - edited 10-27-2022 06:08 PM
As kvbarkley stated, you must select one of the "Sharpness" parameters.
Then Press SET to change the selected parameter.
Then Press SET again to store the new value.
"The attached image is an example (taken from an online tutorial) of the detail set screen with the sharpness parameter simply not adjustable."
Sometimes it's better to read the step-by-step directions in the manual rather than a possibly simplified "online tutorial" 😋
10-26-2022 03:03 PM
Hi and welcome to the forum
A lot would depend on which lenses are attached to the camera, the mode you are set to and whether the lens is set to MF or AF as well as the settings for the camera proper. Have you had this situation with different lenses?
10-26-2022 03:19 PM
Are you looking at taking still images or video?
10-26-2022 03:19 PM
Agree with Trevor... and with such a beautiful camera, I'd stick with defaults and do any final sharpening in post.
10-26-2022 03:29 PM
With the difference in resolution you will get between a 1D series body and the 45MP sensor of the R5, I think I would trial just using the camera set to one of the default settings - perhaps try several and do some tests with those.
Especially if you are shooting RAW, you can do a lot more tweaking in PP. If you really want to go to town, then use something like Topaz Sharpen AI: it does what it says on the box - uses artificial intelligence, with lots of input to sharpen images as well as provide some noise reduction - if you need that.
10-26-2022 03:30 PM
It doesn't matter what lens. I have the 24-105 RF lens, the rest of my glass is EF L glass using the $99 EF-R adapter. Lenses are set to AF and I'm uncertain what other "settings for the camera proper" would affect being able to adjust sharpness in the picture styles menus.
10-26-2022 03:30 PM
Stills.
10-26-2022 03:38 PM
The attached image is an example (taken from an online tutorial) of the detail set screen with the sharpness parameter simply not adjustable. It's like that in any of the picture styles selections, the Portrait one was just the one I grabbed to illustrate my point.
I appreciate all the suggestions, and I usually shoot JPG for just quick run & gun stuff.
It's not so much that I feel a compelling need to sharpen in camera as it is that I'm puzzled why the setting exists without any adjustment possibility. I've not seen this on any other Canon camera menu.
Like I said, I read thru the manual and the PDF manual and just haven't found any information about this, so I come to this wealth of knowledge with my questions.
10-26-2022 03:42 PM
Note the indent:
I think that Strength, Fineness and Threshold are all components of Sharpness. It seems to me that rather than having *no* sharpness control, you have an embarrassment of riches!
10-26-2022 03:55 PM
Hmmm, I never considered that. Interesting.
Thanks!
