03-05-2023 07:44 AM
Hi guys,
I have set my R5 to shoot Raw & Jpg and in the yellow menu I have set it to record separate Raw to the CF Express card and Jpg to the SD card, I have saved this to C1. If I go back to P and change the settings when I go back to C1 the red menu (R&J) are saved but the yellow menu settings are not.
Any ideas??
Thanks
Charles
03-05-2023 08:16 AM
Hi Charles,
Thanks for checking in.
Does it make a difference if the camera is set to shoot photos, not videos? Are you able to save other settings in the yellow menu?
03-05-2023 10:50 AM
Do you have "Automatic Update of Registered Settings" enabled? Though I would only expect that to update your custom settings if you're in that mode (and not if switching to some other mode and changing settings there).
03-05-2023 05:03 PM - edited 03-05-2023 05:40 PM
I've just checked a few things, reset the camera and the Custom settings. In the yellow menu I change the card recording from standard to "separate" and in the red menu changed the jpeg image quality to S then saved to C1. Reset camera, select C1 mode the red menu stays as S the yellow menu reverts back to "standard".
02-09-2024 12:50 PM
I have a similar problems.
i use the P mode to set up the C1 and everything seems working fine/normal till I use the other mode (P, or others like Av,…). The red-1 “image quality” and yellow-1 “record func+card/folder sel” settings were all reset to JPEG/Rec.separately, same as some other settings.
It’s even more time consuming to recheck every single function after used.
Thanks, any help is appreciated!
02-09-2024 01:01 PM
I tested it several times, It doesn’t make any difference with “auto update” on or disable.
it’s set to shoot photos (didn’t test the video yet).
02-09-2024 05:23 PM
@terencexlee wrote:I have a similar problems.
It’s even more time consuming to recheck every single function after used.Thanks, any help is appreciated!
This thread is old. Please start a new thread for your issue. This will put your description of your issue at the top of the page where people can see it. Thanks, ahead of time.
