10-17-2020 07:40 PM
Just purchased 6D Mark II. Overnight the battery Drains. I have a 6D and have usede the same batteries in it and do not have that issue. I purchased new batteries anyhow to see if it was a battery issue in a new camera. Still getting Battery drain overnight. I do not see that GPS or Bluetoothe is turned on. Any help - is there a firmware issue?
10-17-2020 08:59 PM - edited 10-17-2020 09:15 PM
Have you checked the battery compartment for damage or objects?
Perform a full reset.
Also reset the Custom Menus ~C1
Pull the card, remove your lens and cap the body.
Turn the camera off.
Put a new fully charged battery in and let it sit for 24 hrs.
If its dead in the morning, you have two choices:
Rick option: Exchange it
Other Option: Call Canon
Life is too short. I promise you'll love the body once you get this resolved. Many happy memories captured with my 6D2.
My brother got married 2 weeks ago. I let his wedding photographers take first crack at this kiss with their Nikons and flash arrays. I ran up at the very end.. No flash.. ISO 12800 and 1/125 of a second. I didn't get their feet, but I got the shot. You're going to love it.
10-19-2020 12:26 AM - edited 10-20-2020 01:56 PM
Very kind thanks. I don't have the time to spent like I used to. Still love it though.
I got my 6D2 shortly after release. It shipped with 1.0.3.
Changes in Version 1.0.4:
1. Corrects a phenomenon in which in rare instances, the operation buttons and some touch panel functions do not respond.
While I never experienced this behavior, I updated to 1.0.4 in order to avoid it. I ran 1.0.4 for 8 months after 1.0.5 was released. No need to "fix" something which wasn't broken.
I wasn't overly concerned about the fixes in 1.0.5
1. Corrects a PTP communications vulnerability.
2. Corrects a vulnerability related to firmware update.
Firmware Version 1.0.5 incorporates the following fix:
If you care to read about it:
https://asia.canon/en/support/security-advisory-ptp-communication-and-firmware-functions/notice
The vulnerabilities it addresses are extreme.. Knowingly connecting your camera to a compromised device or network.. etc. Wasn't something I was overly concerned about / or a "real world" hazard for me.
I was at another family members wedding this July, so I updated to 1.0.5 before I left. It was fine.
While troubleshooting:
I would suggest sticking with 1.0.4 until you are 100% sure the camera is ok. If you don't experience any undesired behavior after a week, go a head and upgrade to 1.0.5.
Now you can get out there and start enjoying great portraiture this camera offers. ![]()
Cheers
10-17-2020 09:24 PM
10-17-2020 09:35 PM - edited 10-17-2020 09:51 PM
No, those are the two I was referring to.
I have the 85mm f1.8 for portraits. Not as creamy as yours in the background, but also a great match for this body.
Should also add. I've run FW 1.0.3, 1.0.4 and 1.0.5 without any issues. So any of those should be fine.
10-17-2020 09:50 PM
10-18-2020 03:00 PM
First off, Those photographs are wonderful!
Secondly - You are officially esteemed in my world! Moments ago I turned my camera on and it was holding a full battery charge!!!
I've noted the FW updates. But I have not added them. mine has 1.0.4. on itout of the box. Should I install 1.0.5. or wait and see if I experience the problems associated with the update?
Your the man... The guy at the store wanted me to give him $35 to box it up and send it to Canon.
Now if I can just get my Apple Mac to speed up...
EdV
Cheers
10-19-2020 12:36 AM
02-09-2024 04:10 PM
This seems like a common problem, I have only had my R6 mk2 for about 8 months, I use the neewer battery grip, canon batteries and canon adapter for my ef lenses, the same set up I had with my 5D mk3, cannot understand why it’s draining batteries (though not as quick as yours it seems). I have had several canon bodies over many years and never had this problem. Probably going to get it checked out as I’m pretty sure this shouldn’t be happening. I will let you know if I find a solution.
Regards, Steve
02-09-2024 05:08 PM
@Steve07 wrote:Hi,
Regards, Steve
This thread is several years old. Your issue is related to different gear. Please start a new thread of your own so that the description of your issue appears at the top of the page.
