R5 mode button not working!
RonFast
Hi  - My nice new R5 has a fault  - a dead Mode button... I have tried two or three suggestions to cure this, but it remains a problem - It is currently stuck on M and I want to load the latest firmware 1.5 (1.4 installed) - I need to select P to do this, someone suggested that it would load with M selected - sadly not for me! - also tried with the "FIR" ended version of the software. I tried holding down the Q button and pressing INFO to get the mode window - regret that didn't work...
Pressing Q + INFO  brings up the general settings window but the M setting at the top left corner has a greyed out background so inoperative - going a bit crazy here... I guess tomorrow I'll call Mr Canon... but if anybody has the answer to this ...I'd be delighted to be proved stupid.
Kind regards _ Don
Lotus7
Rising Star
Certainly sounds like an early failure, but have you tried the following?:
1. Remove the battery
2. Switch the ON/Off switch to ON with battery removed.
3. Press shutter release for a few seconds.
4. Switch the ON/Off switch to OFF
4. Install a fully charged battery and wait until the red "Busy" lamp stops blinking
5. Switch the camera back ON
Remember, the R5 is always partially powered up whenever a charged battery is installed. the only way to truly power it down and clear registers is to remove the battery.
10 REPLIES 10
Viewfinder
I found that it's in the settings called restrict shooting modes. I turned that off and it fixed this problem. I included a photo of the menu but it's under the custom functions tab, #2, third option down.
