R5 confirm focus beep
Petertoo
With an RF lens on my R5 I get a confirming focus beep if I focus the lens manually, however I do not get a confirming focus beep when using a non-RF lens such as a TS-E lens on my R5 via an adapter. Is there a way of getting a confirming focus bleep with a non-RF lens using an adapter?
11 REPLIES 11
I capture pano shots quite often.  You really should not have to refocus for each panoramic capture, not unless you are focus stacking for increased DoF with a telephoto lens.
mp1c
Hi Everyone!
I found that you can enable 'Focus guide' in the AF menu Number 2. That will show a small focus square which you can move as if it were the AF focus point. It will turn green when you hit focus, but won't beep.
At least a good aid tool, that works perfect. I'm using a, EF mount Carl Zeiss Distagon ZE lens, with the Canon Adapter EF-EOS R.
Hope this helps!
Best,
Friends and Family
