R5 Intervalometer - why 99 shots maximum?
jshirth
I'm using my R5 to take raw images for time-lapse video. I'd like to use the camera's internal intervalometer, but its counter is limited to two digits, or a maximum of 99 images. Is there a reason for this limit? Having a 3, or even 4 digit counter would be most helpful.
Yes, I know I can use an external intervalometer, but if the intervalometer feature has been designed into the camera it seems odd to have this rather arbitrary limitation.
John
EOS R5, RF24-105 f4L IS, RF15-35 f2.8L IS, RF100 f2.8L IS, EF-RF Control Ring converter
EOS 5DMkIII, EF24-105 f4L IS, EF100-400 f/4.5-5.6L IS II, EF70-200 f4L IS, GP-E2, 500D Close-up lens 72mm, 600EX-RT
7 REPLIES 7
kvbarkley
We are not Canon, so we cannot say. I know of no way to effectively report this kind of feature request, either, but I suppose, this forum is as good as any.
rs-eos
To provide product feedback to Canon, go to Canon USA, scroll to the bottom and click on "Feeback" (under the "Contact" section of links).  Then choose "Product".
Ricky
Waddizzle
Follow the wise advice given above.  Contact Canon, and refer to your User Manual.  I would venture a guess that if you set the count to “00”, the camera will keep taking shots until the battery dies on you.
jshirth
Thanks for the comments. I've sent feedback to Canon as suggested by rs-eos, but I'm not really expecting to hear back from them. I've not tried setting the counter to '00' for continuous interval shooting, but I'll give that a try as well. For now, it's back to my external intervalometer.
Oh, and yes, I've read the Advanced Manual - all 927 pages 🙄, but I'm always open to suggestions.
Thanks again.
John
EOS R5, 24-105 f4L, 15-35 f2.8L, 100 f2.8L, EF-RF Control Ring converter
EOS 5DIII, 24-105 f4L, 100-400 f/4.5-5.6L IS II, 70-200 f4L, 600EX-RT
John
Well you missed something:
jshirth
kvbarkley, it's not clear what you're pointing out to me. I do see that '00' gives continuous interval shooting, but I still don't see a way to have the sequence stop at more than 99 shots. My needs typically call for 400-800 unattended shots. I'd rather not have the camera continuing shooting forever.
But thanks for your comment.
John
EOS R5, 24-105 f4L, 15-35 f2.8L, 100 f2.8L, EF-RF Control Ring converter, 600EX-RT, GP-E2,
EOS 5DIII, 24-105 f4L, 100-400 f/4.5-5.6L IS II, 70-200 f4L IS, 500D Close-up lens
John
Waddizzle
I don’t think I was clear about setting the interval to “00”.  What I mean is to set the total number of interval shots to “00”.  That should take you past the 99 shot limitation.
Friends and Family
