04-21-2020 03:07 AM
04-21-2020 05:53 AM
Canon has yet to announce the resolution of the image sensor. The 45 MP figure is only a rumor, and one of the first to start circulating the rumor mills. If the camera is to fulfill what we do know from Canon, then sensor may only have about 20MP of resolution.
04-21-2020 07:02 AM
For video, I want to first understand the tradeoffs.
For one, how is rolling shutter? It could be abysmal. Also, what's the codec?
Regarding 8K, I'm OK with that since when shooting HD on a device that can capture 4K, you get nice oversampling. Remember that "pixels" are not true pixels on image capture devices. Oversampling 4K by capturing 8K would be very nice.
04-21-2020 10:32 AM
Ho hum! ![]()
04-21-2020 10:53 AM
We should take bets about how quickly it takes Ernie to pooh pooh a mirrorless camera after the post first appears. 8^)
You know Ernie, we know your opinion, you don't have to comment every time.
04-21-2020 10:56 AM
News flash that is what forums are for. Opinions! Nobody forces you to read them.
04-21-2020 12:13 PM
@kvbarkley wrote:We should take bets about how quickly it takes Ernie to pooh pooh a mirrorless camera after the post first appears. 8^)
The question isn't how long it takes him to pooh-pooh the camera; it's how long it takes before he buys one.
Ernie ridicules almost everything new, but his curiosity almost always gets the better of him eventually. E.g., he swore he'd never buy a 1DX; now he says it's the best camera he's ever owned. Give him time.
04-22-2020 01:17 AM
@Waddizzle Canon confirmed 8k DCI no crop. Simple math: 8192 / 1.5 x 8192 = 44739242. It's deinitely more than 20Mpx.
04-22-2020 03:10 AM - edited 04-22-2020 05:06 AM
@docusync wrote:@Waddizzle Canon confirmed 8k DCI no crop. Simple math: 8192 / 1.5 x 8192 = 44739242. It's deinitely more than 20Mpx.
True, and you are probably correct. But, if figuring out the sensor resolution were really that simple and straight forward, then why not just simply announce the sensor resolution? Everyone can do the math.
Being able to capture 45 MP at 20 fps would blow the 20MP 1Dx Mark III out of the water. I suspect that there may be a little bit more going on in the R5. Resolution for stills and resolution for video may not be one and the same.
The new C300 Cinema camera is able to read each pixel in a DPAF pair individually for increased dynamic range. One pixel reads the highs, while the other reads the lows. It effectively captures 4K HDR image data at real time. They are calling it DGO, Dual Gain Output.
04-22-2020 10:34 AM
@Waddizzle I think the 1dx3 is a different beast for a completely different purpose. It has a higher battery voltage and can drive the lenses faster, most likely much more superior AF, 1Gb/s Ethernet, a powerful external wifi module, 4 more fps with the mechanical shutter, ruggedness, probably something else that I may not aware of.
I tried the electronic shutter on the EOS R and I'm not a huge fan of it. Lots of distorted images due to the jello effect. It's probably because the sensor read out speed is quite slow. Hopefully the R5 will address this issue.
I had no idea about DGO. It looks pretty cool! Seems like they tried to match the ARRI Alexa https://www.newsshooter.com/2020/04/21/canon-announces-the-c300-mark-iii/
