01-23-2021 12:38 PM - edited 01-23-2021 12:50 PM
Here is the use case:
- Set camera to custom mode, say C1 that has shutter speed 1/400 configured for it.
- While in C1 shoot as usual adjusting shutter speed as need, say to 1/125
- Let camera go to sleep
- Wake the camera up
Observe shutter speed is reset to 1/400
I'd expect this not to be the case because letting camera going to sleep and waking it up is not the same (shouldn't be) as turning it off and then on.
If you enable autoupdate for the custom settings it will keep updating it with whatever you choose duting shotting but this kind of defeats the purpose of the custom mode in my opinion, where you are guaranteed to always start from the same set of settings when switch to that mode.
06-04-2022 02:22 AM
same problem here, I got one R5 for testing and I am used to Sony, Fuji, Nikon and Panasonic, all have there own quirks and tics, but have never experienced something more illogical and inconsistent then the behavior of this R5. I never used a canon, but if this is normal, the R5 won't be for me. as this camera is a loan, i suppose that a previous user has configured some strange things, but even a simple "restore to factory defaults" does not exist
06-04-2022 11:09 AM - edited 06-04-2022 11:12 AM
If you wish the camera to retain your settings, then do not use a Custom Shooting mode.
The whole point of a defining a custom mode is to retain and restore a set of camera settings. There is the option that allows a custom mode to retain changes to the settings. But leaving that enabled defeats the entire purpose of using a custom shooting mode.
06-04-2022 02:30 PM
You miss the point. I turn the camera on. Choose C1, Yes I want the camera to load the camera settings. If I turn the camera off and turn it on and C1 was originally chosen I want it to reload the C1 settings. If I make a change to the C1 setting like 1 stop less exposure compensation, I want it to remember that setting change without storing it to C1. If it goes to sleep or turns itself off, it stil remembers 1 less stop exposure compensation unless. I turn the power button off, When turned on it reloads the original C1 settings. If I change it from C1 to C2 back to C1, i want it to reload the original C1 settings. If I load C1 setting change the exposure compensation and then talk to the person I am taking a picture of and the camera goes to sleep after 5 mins (it turns itself off). I do not want to reload my change to the exposure compensation. It is like the camera has a mind of its own and changes the setting when it feels like it. Not when I want it too. In the middle of a shoot no camera on the planet should change it's own settings by itself. Only if you tell it to. That is plain stupid.
06-04-2022 02:56 PM - edited 06-04-2022 03:20 PM
Check your Automatic Update setting. Everything that you described is exactly how the camera is supposed to work. Be sure to register your settings, too.
06-04-2022 04:02 PM - edited 06-04-2022 05:25 PM
I realize this issue has had many posts and I may be out of line, but this is how I use the custom settings. I don't use it to store specific shutter speeds: rather I choose modes of operation for the kinds of subject I want to shoot. For example, I have C1 set to capture wildlife, so the settings I want include servo focus, eye tracking for animals, high shutter speed, single point AF and AE. C1 is similar but for people and C3 is set to more general tracking.
When I want to define a shutter speed or aperture within those, I just dial it in: for me it is appropriate to just set the shutter speed, aperture etc. as I need it - in other words, I am setting mode of behaviour rather that specific values. I have always checked my settings when I go to take a photo and expect to have to make changes when I shoot, depending on the changing light conditions. If I want to remember a series of settings, then I put into manual mode, Av or Tv mode and shoot that way.
I realize your frustration is that the camera does not recall the last valued you manually dialled in to override those of the C-values but to me, the retention of those values is rather the point. I find the same things on many of the other brands so, to me, that's not unusual.
I shoot Canon, Fuji, Nikon, Olympus and Sony, and must admit I have never had an issue with switching between brands. Sure, different brands approach some of these things differently, but that is the nature of the beast.
06-04-2022 04:24 PM
Reset camera here:
06-04-2022 04:27 PM
@r1ch wrote:You miss the point. I turn the camera on. Choose C1, Yes I want the camera to load the camera settings. If I turn the camera off and turn it on and C1 was originally chosen I want it to reload the C1 settings. If I make a change to the C1 setting like 1 stop less exposure compensation, I want it to remember that setting change without storing it to C1. If it goes to sleep or turns itself off, it stil remembers 1 less stop exposure compensation unless. I turn the power button off, When turned on it reloads the original C1 settings. If I change it from C1 to C2 back to C1, i want it to reload the original C1 settings. If I load C1 setting change the exposure compensation and then talk to the person I am taking a picture of and the camera goes to sleep after 5 mins (it turns itself off). I do not want to reload my change to the exposure compensation. It is like the camera has a mind of its own and changes the setting when it feels like it. Not when I want it too. In the middle of a shoot no camera on the planet should change it's own settings by itself. Only if you tell it to. That is plain stupid.
Doesn't this do what you want?
06-04-2022 05:21 PM
No John, this does not do what I want. I don't want the setting updated. I want C1 to always be the same when I turn the camera off, change from TV or C2 to C1. I don't want C1 updated automatically.
06-04-2022 05:28 PM - edited 06-04-2022 05:32 PM
"For example, I have C1 set to capture wildlife" I use C1 for birds in flight and I don't want those settings ever overridden.
If I am shooting snowy egrets only, I want to lower the exposure for 1 stop to not blow out highlights. I want that temporary change to stay in the camera as long as I don't turn off the power button. Once I turn off the power but it loads the standard C1 for birds in flight settings and forgets my temp settings. It does not remember snowy egret 1 stop lower exposure.
As it is now, if the camera goes to sleep, it will forget my temp settings and load C1. Don't change my temp setting ever unless I change modes to Av or C2 and back or I turn the camera on and off.
06-04-2022 05:35 PM
Increase the power off time and deal with battery life impact.
