EOS R1 - locking up
KenC2
I am a back-button focus user:  the AF-ON button and the AE Lock button are programmed to start autofocus;  Half-press of the shutter button is programmed to only meter; and the Smart Controller and the Multi-controller are disabled.  As default, I am using spot-AF in the middle of the frame.
If I wake the camera up from sleep mode by pressing anything other than the shutter button, the camera occasionally locks up.  By locking up, I mean the spot-AF symbol moves away from the middle of the frame (usually goes way left in the frame) and the dot in the middle of the spot-AF symbol goes away (essentially now depicting 1-point AF).  In order to get the spot-AF symbol back and in the middle of the frame, I have to either take the battery out and put it back in... or load my initial settings from the flash card.
The same lock-up sort of thing used to happen with my previous R-3, except that lock-up was a true lock-up (the camera wouldn't respond at all... couldn't even turn it off... the only remedy was to take the battery out and put it back in).  (This R-3 issue was fixed at some point with a firmware update.)
I have two R-1 bodies, and they are both experiencing this issue.  Has anyone else experienced this?  Also, WHAT IS THE BEST WAY TO RELAY THIS INFORMATION TO THE CANON ENGINNERS?
4 REPLIES 4
FloridaDrafter
Go to the Canon Support page, scroll to the very bottom, and click the [+] Feedback link.
Newton
NatalyaP
Greetings KenC2,
I am sorry to hear that both of your EOS R1 camera bodies are experiencing the same lock up issue, though slightly different from your EOS R3 camera. You are able to submit direct feedback by clicking on the following link and then clicking on the feedback option located towards the top-right portion of the page. This allows for you to provide a detailed description of when this issue occurs.
https://www.usa.canon.com/
In the meantime, if you would like to send your camera bodies to our facility for repair, you may begin the process by visiting our online repair portal.
Canon U.S.A., Inc. has created a new online repair portal that allows you to set up service in a few simple steps. The repair portal gives you the ability to set up service for multiple pieces of equipment at once, and to receive a repair estimate in the majority of cases, depending on your model and issue. The portal also allows you to upload images or videos that will assist us in repairing your product. You can also select how you wish to be notified of the progress of your repair. The portal's service history section allows you to view all services that have been performed on any of your camera or video products since January 7, 2020.
Please follow the link below to access our online repair portal to arrange for service:
https://mycanon.usa.canon.com/signin
Instructions for Accessing and Using the Online Repair Portal.
You will need to access or create your My Canon Account.
If you already have a My Canon Account and your product is already registered, simply click on the “Get Repair Services” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you have a My Canon Account and your product is not registered, you must register your product first. Click on the “Get Repair Services” link on the left menu, then click on the “Register Product” link on the right. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
If you do not have a My Canon Account, you will need to create one. After you create your account, click on the “Add Product” link to register your first product. After your product is registered, click on the “Get Repair Service” link on the left menu and follow the onscreen instructions to arrange for service for your product.
Once you have completed the repair request, you will have an opportunity to print a copy of the request for your records. This request form will also contain shipping instructions and an address label that you will attach to the outside of your shipping box when mailing your equipment for repair.
RF1830
I am having the same issue with that set up. When the camera locks up I have to pull the battery reload the battery and turn the camera back on. This happened four times on my last outing. Once when I turned the camera on and tried to take a shot. I tried to clear the customize buttons but that has not helped.
KenC2
RF1830,
Again, when I say the camera "locks up", I mean that the Spot AF symbol moves away from the middle of the frame for no reason and cannot be moved from thereon.  I have let the Canon engineers know about this issue.  I have found three ways to overcome this issue in the meantime.  (1) Wake the camera up by pressing the shutter button first (I know this is a pain, but this seems to prevent the locking up issue.  (2) I have programmed the Set button so that it's set to return the Spot AF Point to the middle (this is one of the custom options for the Set button).  So, If I forget to do (1), I can just hit the Set button.  (3) In case somehow (2) stops working, I have saved the original camera settings to the memory card.  I can recall (i.e., upload) the settings via the menu option.  While (2) gets me back to my desired settings immediately, (3) takes a few seconds (but it's a good backup to have).  Either works faster than taking the battery out and back in.
