Use custom mode to save to a different card
SamBloxham
Hi All,
Is it possible to use the Custom modes to alter settings within the ‘Record func+card/folder sel.’ Menu, or the file name or folder name options?
What I ideally want is to use C1 to record images to the Cf card and C2 to record to sd card. That would be on an R3/5. On the R1 I’d want to do the same but pick which CF slot.
Everything I’ve tried doesn’t seem to allow that. As I switch between C1 and C2, the record function remains as whatever I last set it at. This appears to be the same for filenames and the folder selection.
Has anyone else had this requirement and found a work around?
The ideal end result is that I have different sets of images recording to two different cards, depending on which mode I pick. Switching between the card function setting as I shoot isn’t an option, it’s too fiddly and would be easy to get out of sequence.
Thanks,
Sam
3 REPLIES 3
Waddizzle
Older DSLRs had much smaller menus. The User Manuals listed which settings could be saved to a custom mode.  I don’t recall whether memory cards settings were included.
My point is that not every setting was included for custom modes. I assume that there was a good reason not to include card settings.
Your observations are valid. You should make a suggestion to Canon to include them in a future firmware update.
jrhoffman75
@SamBloxham wrote:
Hi All,
Thanks,
Sam
I don't know about the R5, but R1 and R3 allow you to save camera settings to card.
Not a quick as switching between C modes, but it will achieve what you want.
SamBloxham
Thanks both for your input.
Sam
