02-25-2021 08:35 AM - edited 02-25-2021 08:38 AM
I’m using a remote trigger via the shutter release port. After image capture, the LCD screen only shows the horizon level indicator, but no preview of the taken image. The only way I can see the image I’ve taken is to unplug the cable to the remote trigger. How can I see the image preview without having to do this after every capture? I'm using an EOS 5D MkIV.
02-25-2021 10:41 AM
Flash out is to trigger a flash, not the camera.
You need a remote shutter trigger, not a flash trigger. I hope you have not damaged your camera.
02-25-2021 10:56 AM
You won't know whether anything is damaged until you plug in a real remote shutter release.
02-25-2021 11:17 AM
Just plugged in the RS-80N3 and all works OK
02-25-2021 09:33 AM
What is your review time set to?
02-25-2021 09:40 AM
8 seconds.
