07-02-2022 02:49 PM
Hello need some help suddenly the play button stop to work and I can't see my pictures.
07-02-2022 03:26 PM - edited 07-02-2022 04:11 PM
If you have not done so already, when you have press play, then press the Info button. That may restore your view of the images. It cycles through a range of displays, including a blank screen..
07-02-2022 03:55 PM
Doesn't work and when I press the menu button the lcd screen goes back
07-02-2022 04:08 PM
The menu button is not the right one. Sorry, in this model it is the DISP button. Try that
07-02-2022 04:14 PM
Sorry my mistake when I press the display button the lcd screen goes black
07-02-2022 04:16 PM - edited 07-02-2022 04:19 PM
So, just to make sure we're all on the same page. First press the blue arrow (2nd button from bottom- left), if the screen is black, THEN press the DISP button, (top left) a couple of time to see if it cycles through.
07-02-2022 04:23 PM
I hope that works for you. However, assuming the LCD works when you press the menu button and you can see the menu, and that you have actually got an image to view, then I suspect that the blue view button is not working. Considering this camera is about 18 years old, it is almost certain that it cannot be repaired.
07-13-2022 06:01 AM - edited 07-13-2022 06:01 AM
Has anything worked? If so, please mark it as a resolution, please!
07-13-2022 06:09 AM
Excellent. If you would be so kind as to mark the response that resolved the issue for you, then others will know the answer if they have a similar one, and we won't get people continuing to post solutions.
08-17-2022 03:36 PM
I fixed my play button on my Canon XTi using a Qtip and sanitizer just let the sanitizer go inside the edges of the button I then press it leave it for a moment in order to the sanitizer evaporates and now it works beautiful.
