01-08-2023 05:34 PM
A pink line appeared on my screen while shooting on my R6 (less than a year old). unfortunately the line is on the images. Same issue with different cards and it's consistently there.
I haven't brought it back yet, but my biggest issue is how to fix the images?
01-13-2023 07:57 AM
I managed to open the folder in rawTherapee now. What do I do from here? Did you do some command to the image or edit it somehow to remove the bad pixels?
TIA
01-13-2023 08:32 AM - edited 01-13-2023 08:47 AM
As written at RawPedia:
So you need to put the badpixel file in the same folder as you dark-frame folder.
So Preferences, Image Processing. Choose a folder for dark-frames. After that you put the badpixel file in that folder and restart RawTherapee.
When you have it up running you can just export to 16 bit Tiff and edit in Lightroom if you prefer that.
05-01-2024 10:26 PM
Hi Peter! I also have the same problem on my photos taken by 60D. would you please make a tutorial on how to use raw therapee? thank you so much!
05-02-2024 09:25 AM
Sure, but it also depends on how serve the damage is https://kameratrollet.se/use-rawtherapee-to-deal-with-laser-damaged-camera-sensors/
05-02-2024 09:49 AM
how did you generate the .badpixels extension file?
05-02-2024 10:00 AM - edited 05-02-2024 10:46 AM
I just right clicked and created a new text file. I also changed the extension from .txt to .badpixels
You can reuse the one from 5DIV and just change the name.
05-02-2024 10:43 AM
This is my raw photo. https://drive.google.com/file/d/1awBb_02EjU0r2NRywir5eKStSJzjpQsN/view?usp=sharing https://drive.google.com/file/d/1awBb_02EjU0r2NRywir5eKStSJzjpQsN/view?usp=sharing . I tried using the 5DMIV but it made the photo look pinkish. My apologies for bothering
05-02-2024 11:08 AM
I will take a look when I get home.
05-02-2024 11:50 AM - edited 05-02-2024 12:10 PM
I downloaded your file. Are you sure the sensor has been hit by laser? It seems like something else. The badpixel list will not work for this. Are the lines moving around or they are always at the same place?
Perhaps a dark frame will work better. Could you take a raw file with lens cap on? ISO 6400, f/5.6 and 1/100 sec.
05-02-2024 12:30 PM
https://drive.google.com/file/d/1n8QQf47RMGqAHZrSkUGDFq9UWeVw18XF/view?usp=sharing https://drive.google.com/file/d/1nfPZY3b8oGZlBigwnna1V6nHThrNQu06/view?usp=sharing This camera was given to me only. I do not know much of the history, or the owner. But he gave me 2 batteries, an original and a third-party one. I noticed that those lines appear on the third-party batt.
