Number sequence out of whack!
Tintype_18
Attended a dog show and took 144 photos. Downloaded them from the card to my laptop. OK, so far. When I went to view them. the were interspersed with photos that my wife too weeks ago. Her photos would be IMG.XXXX.jpg but my photos would be IMG.XXXX,jpg(1). Any ideas what happened? Need to check the camera numbering sequence,  Canon T7?
Thanks in advance. BTW, going back to the show tomorrow. Show was in a covered arena with open sides so I had to play with settings. Good experience as I had to watch settings and adjust over/under exposure, f/stop, lens speed, ISO, etc.
Hate to go through all 144 and transfer to a new file. Should have made the file before downloading the card. Live and learn.
John
43 REPLIES 43
I bought it late 2018.
John
"This PC > Pictures > Dog show 2021.
Yours shows the D drive, mine doesn't. Difference?"
Same, same!  I simply have an additional 2TB hard drive. Windows 10 labels it as the 😧 drive. It is no different than yours where you have pictures stored on your C: drive.  This is just used as a additional storage space since I take so many photos.
When you shoot professional you are obligated to store photos, or jobs, for a period of time.  This requires a lot of additional HD space. I have four 2TB external HDs for more long term storage.  I keep each cilent's work for a minimum of six months and usually a year or more.
EOS 1DX and many lenses.
"I put my settings as I needed or felt I needed. As I said, this was a learning experience for me ..."
You just have the very common beginner's learning pangs. Keep doing it and eventually you will learn what is what and how is how.  The advice offered is just a stepping stone to get to that point faster.
"...  but can I attach a photo to an email from there or do I have to change it to a jpg?"
Do you mean right at the dog show? Or, do you mean after you get home and have u/l to your computer? If you are emailing a snapshot at the dog show use your iPhone. If it is at home, any editor will save you a properly sized jpg for sending in an email.
Don't have an iPhone. I should have been more specific. D/L to the computer and attaching photos from the MS Photo Extension for email.
John
jrhoffman75
Tintype_18. Can you post a screenshot of what you see when you open the file folder containing your RAW images? Thanks.
"... attaching photos from the MS Photo Extension for email."
Without actually saying it, I assumed you realized you need to stop using Explorer as you input software. Its time you moved to a editor of some sort. Now you don't have to do any actual editing if you don't want to but that is where your photos belong.
If you are emailing photos you need to make them for email unless, or FB, or Instagram, etc. Unless you are sending the final product. However it also should be sized properly for the intended final use.The dog sample you u/l here on the forum was 42x28 inches big. Is this your common practice to email like that?
If I remember correctly you have PSE?  Use it for u/l to your computer. It will do everything you need and mostly do it automatically. DPP4 does it also but it is a little harder to get going than PSE is.
  1. In the Organizer, select the photos you want to email to a friend.
  2. Open the Share panel and select Email Attachments (the photos).
  3. Choose a quality setting for the attachment and click Next. ... (allows you to make them a manageable size)
  4. Add recipients. ...
  5. Click Next.
Sometimes we make things harder than they need to be.
This is a screenshot for my Landscape file. The first ones in the file are jpg but others are jpg and CR2. This screen shot shows the mix of the two. I load the card in the side of my laptop,follow the sequence. I can let the photos go to the general Photo file or I can specify a certain folder as Landscape. Took a while to figure out how to do a screenshot. Let's hear it for Youtube! If this needs to go to another post, please do it. Have some other questions. TIA.
John
I'll experiment with sending photos from PSE. I have two emails.
John
