R5 Mark II Playback bug (2nd last image)
noms78
This bug likely appears under other settings too, but these are the ones I typically used when testing several R5 Mark II bodies at my local camera store in recent months. A factory reset did not resolve it.
Settings:
  • Image quality: RAW
  • Drive mode: Single shot
  • Image review: Off (2nd-last Shoot menu)
  • Card inserted (e.g., SD)
Procedure:
  1. Take two photos.
  2. Press Playback.
  3. Press the Info button to check the sequence number.
Expected (no bug):
  • Last frame shows as the final number (e.g., 2/2, 3/3, etc.)
Bug present:
  • Playback shows the 2nd-last image instead of the last frame
Serial numbers with playback bug:
  • 146 202 1 01 XXX
  • 149 502 3 00 053 (1.0.2)
  • 149 502 3 00 160 (1.0.2 -> 1.1.1) - bug persists
  • 154 502 4 00 368 (1.0.3)
  • 154 502 4 00 382 (1.0.3)
Serial numbers without playback bug:
  • 149 502 3 00 534 (1.0.2)
  • 151 502 3 00 043 (1.0.3)
I also posted about this bug in several reddit forums, for example:
https://www.reddit.com/r/CanonR5/comments/1mrin6r/r5_mark_ii_playback_bug_2nd_last_image_displayed
1 REPLY 1
noms78
There is no playback bug! The issue was caused by using older, slow SDHC cards (30MB/s) instead of SDXC/CFB.
