07-11-2024 07:35 PM
Hi, I would really appreciate your help, guys.
I was shooting with my Mark 1DX II and all of the sudden started to take some greenish photos.
Its weird because its no constant, I can shoot literally a houndred photos and they are all fine, but ramdomely one green.
I uploded a couple of examples of a burst of photos so you can check the light in the room and all the sudden a greenish photo.
I tried with a different memory, a differente battery and still the same. I dont know what else to do.
Thanks a lot
07-11-2024 08:08 PM
Bardinetsimon,
Do you have any kind of filter on the front of your lens? If so, try taking it off and see if it makes a difference.
Also, what White Balance are you using? If it's AWB, that might account for it.
These are just a couple of suggestions.
Steve Thomas
07-11-2024 08:22 PM
Steve, thanks for your reply, I honestly appreciate it a lot.
No, I didn't have any filters on the lense. Actually I also tried with different lenses and still the same.
And also changed the white balance from auto to other setting and still the same 😩
07-11-2024 09:17 PM
Looks like flickering light source.
07-11-2024 09:59 PM - edited 07-11-2024 09:59 PM
I agree with Peter that it looks like light flicker which results in a varying color temperature. Assuming you shot these in RAW, set the white balance to white priority in post and see how it does. I use white priority often when shooting sports under constantly changing lighting and it generally does a good job of either nailing the balance or getting close enough to easily dial in the proper color temp.
Rodger
07-11-2024 11:45 PM
I will try that. But it's weird because after that I did some photos in different environments, different lights and still the same.
I set the WB manually and happened again. I don't know what else could it be. Even it happened a couple of times when I was going to record some videos.
If it's the sensor it's rare that happens not continuously, but rather very often.
Thanks for your reply and suggestion
07-12-2024 01:23 AM - edited 07-12-2024 01:24 AM
If you're using a specific white balance setting (not AWB), and the lighting is consistent, the results should be consistent.
Is the lighting varying, like the mentioned flicker (of fluorescent light), or are there other photogs shooting with flash and some of your shots are catching their light?
Different memory or battery, or lens, would have nothing to do with the color rendition you are getting. You have to figure out what is CHANGING DURING a succession of shots.
07-12-2024 09:38 AM
Well, in the case of the photos that I uploaded as example, there was a big led screen that could have affected the light for sure, but I don't think that dramatically.
But the problem is that was still happening when I tried outside with a bright sun, so I don't know.
And well, I tried the battery and the memory because I read it online. As you can see, I'm lost and clueless here.
Thank you so much
07-12-2024 03:10 PM - edited 07-12-2024 03:14 PM
Would you mind sharing some problematic raw files taken outside in sunlight? And if possible, one that is not problematic from the same time.
I just want to check that the black level is correct.
07-12-2024 07:26 PM
Hi, Peter. Of course, of course. I don't have with me because it's on "repair", but I will have them on Monday and I'll send you the pictures.
Thank you
