07-13-2024 08:22 PM
In charge of taking pictures for the upcoming golf fundraiser for my sons football team.
I will be roving on the green as well in charge of individual pics as golfers enter.
I currently have a canon Rebel T7. I also have a 75-300 mm lens (which I have been using mostly)
Is there a good one for portraits that anyone would recommend?
I was looking at the 135/mm.
Thank you.
07-13-2024 08:37 PM
football mama,
The 135 has a good reputation.
A suggestion might be to go online and do some searches for sample photos taken with the 50mm, The 85mm and the 135mm and see which ones you think you might be comfortable with. I personally prefer the 85, but that's just me.
Steve Thomas
07-13-2024 08:47 PM
this is such a great idea.
what do you like about the 85 versus the 135?
07-14-2024 12:05 AM - edited 07-14-2024 12:12 AM
footballmama,
I also own a T7 along with both fixed focal length and zoom lenses including 4 of the lenses mentioned below. Since the T7 is an APS-C (crop sensor) camera and the equivalent focal length for a full frame or 35mm film camera is 1.6X the focal length of the lens on your camera, my comments references the full frame equivalents of the fixed focal length lenses.
Hope the above helps.
Good luck!
07-14-2024 01:13 AM
footballmama,
As Zakslm mentioned, your T7 is a crop sensor camera. That means you have to factor in a 1.6 magnification, or zooming power, or whatever you want to call it.
An 85mm lens becomes the equivalent of a 136mm lens.
For the kind of work you are talking about, I personally feel a 135mm lens is overkill, because a 135mm lens turns into the equivalent of a 216mm lens; and because it's a fixed lens, you can't zoom in or out. You would have to stand quite a ways back to get your shot, and in some tight quarters, you might not have that option.
I do not have the 85, but from what I've seen, the optics are terrific, and as Zak describes, fits the bill as a "short telephoto"
If I could throw a suggestion into the mix, try taking a look at the Canon18-135mm IS USM lens. IS stands for image stabilized, and USM stands for ultrasonic motor, which drives your autofocusing. It's whisper quiet. The optics are superb.
I was lucky enough to be gifted one, and it stays on my camera 90-95% of the time. Being 18 to 135mm, it covers a wide range of every day shooting conditions.
Just a thought.
Steve Thomas
07-14-2024 09:37 AM
Wow thank you so much
ideally I would also like to use whatever lens I get for this for the season too. The one I have now does a great job but am looking for a sharper picture quality
07-14-2024 09:37 AM
Would the 18-135 be good for on the field action shots too?
07-14-2024 10:37 AM
Do you know if your sharpness problem is lens related or technique related (I.e. potential camera shake)? The 75-300 is not one of Canon's best lenses, but central area, where you would likely be framing typical golf subjects, is good. What are you viewing your images with? Can you post an out of camera image on Dropbox or similar site for examination?
07-14-2024 11:02 AM
Great advice going on here. What seems to be standing out is you have a crop body camera and are looking for good FL coverage for an upcoming golf event. However, you also want something to that provides year around usefulness.
I would recommend a zoom. Its more difficult to do portraits on the crop body camera. If you go with a shorter focal length, you have to get closer to "fill the frame". I'm not saying it isn't possible, but you will be doing this with your legs. If you are beyond the edge of a green or have to contend with people, this might become challenging.
I liked the EF-S 18-135 recommendation. I owned this lens and found it to be extremely versatile. Edge to edge sharpness was above average, especially when stopped down.
f/3.5 f/4.0 f/4.5 f/5.0 f/5.6
18mm 24mm 35mm 50mm 76mm
Looking at the table above, you can see that you get an acceptable level of subject / background separation and decent (shallow) depth of field between 24-50mm. You will likely use somewhere between 24-40mm FL for full body 1-4 person full body portraits.
Course perspective can be achieved 18-35mm. A zoom up to 135 will also give you the ability to capture a golfer's concentration and facial expression when he/she is putting.
Prime lenses are great, but I'm making this recommendation to minimize lens changes and keep you from running around.
I also want to mention what zakslm said in point 5. At some point, I would consider upgrading your 75-300. It is not one of Canon's best endeavors. It lacks IS and is an entry level optic. It does take pictures, but is not known for its IQ or clarity. The EF-S 18-135, 55-250 and EF 70-300 USM II will all outperform it.
Good luck at the golf event, and have fun.
07-14-2024 11:36 AM
Please forgive my oversight.
Apologies. I didn't refresh my screen and seem to have missed the football requirement. Unless game play is directly in front of you and you are on the sidelines, your existing set up is not going to be great for individual players. If the game is at night, you are not going to be happy. Shooting from the sidelines can also get you run over. Please be careful.
My post above for the golf fundraiser remains true. Football and soccer are different stories. For these you are going to need a lens with a much longer focal length. Also something with better low light performance if you will shoot at night. You are looking at two vastly different shooting scenarios. Golf vs football. We have a resident sports photography expert. I'm going to ask him to join the discussion.
