03-19-2014 07:39 PM
I've installed the necessary software from Canon, but no luck. Any suggestions?
12-26-2017 11:02 PM
Why should you need to know this. I have never had a digital camera that when plugged in to an active USB port was not immediately recognizable by the PC or Mac. Do Canons have a problem with that? It is a capability that has been in most USB devices since the moid 90s.
12-22-2014 10:35 PM
I am having a similar issue. I just bought a new MacBook Air about a month ago and connected my Digitial Rebel via the USB cord. iPhoto (and Image Capture) recognize the camera but no photos show up. I double checked that there are images on the CF card by viewing the photos on my camera.
I have OS X Yosemite and I installed the software that came with the camera.
I'm hoping there is a fix to this even though my camera is about 10 years old now!
12-23-2014 12:17 PM
@pdxjasmine wrote:I am having a similar issue. I just bought a new MacBook Air about a month ago and connected my Digitial Rebel via the USB cord. iPhoto (and Image Capture) recognize the camera but no photos show up. I double checked that there are images on the CF card by viewing the photos on my camera.
There's a recent article in another thread that seemed to suggest that older Rebels used a different protocol to talk to computers. Though that protocol is now antiquated, it apparently still works; but you have to manually set the camera to use it. I'm not sure which thread it was, but it's one that's still active.
12-24-2014 12:37 AM
After searching the Apple forums for a solution, I got it to work. I changed the Communcation setting in the camera from 'Normal' to 'PTP' and everything worked just like it used to!
03-30-2015 04:35 PM
Jasmine -
Thanks so much for the tip. I have been searching for a month to correct this issue and you saved me fron insanity. Thank you. Thank you. Thank you!!!
04-18-2015 03:09 PM
Where did you find the Communications setting?
I have used my several years old Canon Rebel with my Mac many times. I have never had a problem uploading pictures. Suddenly the camera will not speak to the Mac. I know the Mac recognizes the camers as it is listed in the System Utilities.
Any help?
Canon's instructions for connecting camera to computer are of no help.
Thanks.
05-04-2015 12:00 PM - edited 05-04-2015 12:03 PM
I am having the same issue. I have upgraded to Yosemite and was able to still upload my pictures off the camera. With the new update changing iphoto to "Photos" I cannot upload the photos off of the camera, whether it's by directly through the SD reader or through attaching the camera via the cord. Through this forum I was able to ascertain that the macbook is reading the camera...but, I canot access the photos. Also, other forums have suggested switching camera to PTP rather than "normal" from what I can tell my camera does not have that in the menu options.
Please advise,
Thank you!
09-13-2017 01:23 AM
09-13-2017 09:17 AM
Hey there Ellens1!
Only a handful of older models will have the ability to change the communications mode from "Normal" to "PTP." The Rebel T6 is always set to PTP because modern computer operating systems recognize cameras right away when cameras are set to PTP (Picture Transfer Protocol).
If you're using a MacBook, you might need to make sure your MacBook is plugged into its power supply so that the USB port is given enough power to initiate the picture transfer. You'll also need to make sure your camera is connected directly to your MacBook, not to a USB hub or adapter.
If you're doing these things, and you're still not having any luck, we recommend reaching out to technical support. They'll get you up and running in no time!
Our US-based, tech support is 100% free at 1-800-OK-CANON from 8am to Midnight (ET) weekdays and from 10am to 8pm (ET) on Saturdays.
Outside of the USA, go to http://global.canon/en/support/ for options.
We hope this helps!
06-19-2015 05:22 PM
