07-20-2021 11:22 PM
I have four SD cards, Sandisk of various stripes, 128 through 16G. Today when I went to the camera I got the "can't access card, format card or change card" message. No ERR, just that. I've done all the possible research and haven't found a solution yet. I can try buying a new card but why would that work? I've had the camera a few weeks and really fell in love with it Dang! Win 10 Home Pro 24G RAM, Gigabyte Mobo, i5 CPU. Help! There are older posts on this board but they haven't helped me.
Thanks
07-21-2021 05:10 PM
I get image on screen auto focus dots depress shutter half way no focusing, all the way shutter clicks. Clikck review and it says no image. Flash is supposed to be off but pops up. Set on auto, no flash, quick mode. Was working fie the last time I used it.
07-21-2021 05:13 PM
Call 1-800-OK-CANON
07-21-2021 06:18 PM
after a bunch of questions they they said I will conet you then I was disconected. The other time i went to the help line and got thfough the questions they said that model info is online only so another dead end.
07-21-2021 07:56 PM - edited 07-21-2021 08:00 PM
@Rocks wrote:after a bunch of questions they they said I will conet you then I was disconected. The other time i went to the help line and got thfough the questions they said that model info is online only so another dead end.
First, go into the menu and reset all camera settings and all custom functions. Instructions for that will be in your manual.
Then set camera to P(rogram) mode on the dial and go outside in daylight and try to take a picture.
If that doesn't clear up the problem, a few suggestions:
1. is there a camera club near you. Often if you go to a meeting someone might be able to help you. I know my club does that.
2. is there a camera store near you
3. here is the website for Canon support: Canon U.S.A., Inc. | Service & Repair
4. Midwest Camera has been recommended by some folks on this forum
5. Cameraworks of Colorado Springs has been recommended by folks on the Ugly HedgeHog site
I have no direct experience with either of them.
07-28-2021 12:40 PM
As it turns out, there was a broken pin inside the card reader slot. I have NEVER had a problem like this. The camera was purchased via eBay. I sent it back to the seller, who accepted my return but wanted to claim that I had done the damage. I am still waiting my refund from eBay. It's been about two weeks.
07-28-2021 12:42 PM
There was damage to the card slot, a broken pin.
07-28-2021 08:13 PM
I did get a full refund from eBay,so there's that. AND I have a functioning 6D Mk 2, which is a lovely FF camera.
07-28-2021 08:39 PM - edited 07-28-2021 08:40 PM
I am glad that you got your money back, ebay is very good about that making it quite safe for buyers.
The SD card interface is far more robust than the tiny pins of a CF card socket connector but even SD card sockets can be damaged. The previous owner probably made a mistake and tried to force fit a card that wasn't going in properly or bought a poor counterfeit card where the dimensions weren't quite correct.
Rodger
