09-11-2021 05:13 AM
I bought an EOS R with battery grip. I found out so far, that I only can charge the accus inside the grip using the AC adapter which was sold with the grip. No other adapter / laptop / powerbank works. This isn't really helpful.
My son bought an EOS R5 and the battery grip. There was no AC adapter included with the grip and he found out so far, that only the Apple adapter from his girfriends iPhone works. This is also not really practicable.
How can we charge our cameras / battery grips from some unspecific USB source like Wall adapters, Powerbanks, Laptops (we use HP & Asus)?
I will buy a R5 or R3 soon, and there is a need to solve this issue in advance.
With best regards
Gerhard
09-11-2021 12:28 PM
If you are having trouble using USB-C to charge your camera, this video may help.
09-11-2021 09:02 AM
@Gerhard56 wrote:Hi,
With best regards
Gerhard
What is an "accus"? What brand of battery grip are you using? Canon does not support third party gear.
I do not think the Canon battery grips support USB charging.
09-11-2021 09:41 AM
09-11-2021 11:02 AM
Camera batteries can supply a lot of power, so it takes a lot to chage them. I am sure you need a high power adapter. What is your question?
09-11-2021 12:28 PM
09-12-2021 01:23 PM
@MikeSowsun wrote:If you are having trouble using USB-C to charge your camera, this video may help.
I see you selected my video link as a solution to your charging problem. Can you tell us what part of the video was the solution? It may help others with the same problem.
09-12-2021 02:39 PM
09-13-2021 03:41 AM
09-13-2021 07:31 AM - edited 09-13-2021 07:31 AM
The LP-E6N and the LPE-6NH are high capacity batteries that need high voltage and capacity to charge. I originally thought it would be impossible to charge a 7.2V battery with a 5V USB circuit.
I am not sure what "magic" is used but I suspect your problem may still be one of the items covered in that video I linked to.
09-13-2021 07:42 AM
I haven't looked at the circuit in the camera but they could either be using a DC to DC inverter to step up the 5V from the USB port to a higher voltage, in that case the current draw is substantially greater than that needed to charge the pack since the wattage on the input side of the inverter chip will be at least 10% greater than the wattage on the output side to provide for the charging current/voltage requirement and to account for the less than 100% efficiency of the inverter.
Another possibility is the LP-E6 series allows split charger where the two 3.6 volt internal cells in the battery are charged in a controlled parallel instead of serial mode so required charging voltage is 1/2 of normal.
I experienced a problem with a brand new LP-E6NH battery which is going back to Adorama today for exchange. The LP-E6 design is not something I like, the scheme is a bit too clever leading to reduced reliability. Canon issued a customer service note to get around one of the problems for the LP-E6 battery not charging but the basic design will never yield the reliability of the simpler pack designs used in their 1 series and in many other bodies. Canon does best when it stays away from gimmicks and produces high performance cameras which is what they had done for years. I am afraid that Sony competition is falsely driving them into "feature creep" at the cost of solid functionality.
Rodger
09/26/2023: New firmware updates are available.
CN-E45-135mm T 2.4 L F - Version 1.4.0
EOS 1DX Mark III - Version 1.8.0
EOS R6 Mark II - Version 1.2.0
08/18/2023: Canon EOS R5 C training series is released.
