Is the R3 the only Canon camera with panning assist?
ExpoGuy
I'm trying to find out if the R3 is the only Canon camera with panning assist. I can't find this feature with any other Canon camera. Keep in mind that panning assist is not the same as panning mode. On some message forums people get those confused. Panning assist uses advanced technology.
I was hoping the R5 II had panning assist, but I don't see it.
Yes only the EOS R3 has panning assist, and it is not included even on the EOS R1 or EOS R5 Mark II.
Brian
8 REPLIES 8
johnrmoyer
Whiz
Whiz
https://www.canon-europe.com/pro/stories/using-panning-assist-ibis-high-resolution/
https://cam.start.canon/en/H001/supplement_0120.html
Lenses Compatible with Panning
The following lenses are compatible with Panning mode and [Panning Assist] (as of March 2025).
This information applies to the cameras noted below.
  • EOS R3 (Firmware Ver. 1.4.0 or later)
  • EOS R6 Mark II
  • EOS R7
  • EOS R8
  • EOS R10
  • EOS R50
  • EOS R100
Type of Lens Lens Name
RF lenses RF24mm F1.8 MACRO IS STM
RF35mm F1.8 MACRO IS STM
RF85mm F2 MACRO IS STM
RF100mm F2.8 L MACRO IS USM
RF135mm F1.8 L IS USM
RF400mm F2.8 L IS USM
RF600mm F4 L IS USM
RF600mm F11 IS STM
RF800mm F5.6 L IS USM
RF800mm F11 IS STM
RF1200mm F8 L IS USM
RF10-20mm F4 L IS STM
RF14-35mm F4 L IS USM
RF15-30mm F4.5-6.3 IS STM
RF15-35mm F2.8 L IS USM
RF16-28mm F2.8 IS STM
RF24-50mm F4.5-6.3 IS STM
RF24-70mm F2.8 L IS USM
RF24-105mm F2.8 L IS USM Z
RF24-105mm F4 L IS USM
RF24-105mm F4-7.1 IS STM
RF24-240mm F4-6.3 IS USM
RF28-70mm F2.8 IS STM
RF70-200mm F2.8 L IS USM
RF70-200mm F2.8 L IS USM Z
RF70-200mm F4 L IS USM
RF100-300mm F2.8 L IS USM
RF100-400mm F5.6-8 IS USM
RF100-500mm F4.5-7.1 L IS USM
RF200-800mm F6.3-9 IS USM
RF-S10-18mm F4.5-6.3 IS STM
RF-S14-30mm F4-6.3 IS STM PZ
RF-S18-45mm F4.5-6.3 IS STM
RF-S18-150mm F3.5-6.3 IS STM
RF-S55-210mm F5-7.1 IS STM
EF lenses EF85mm f/1.4L IS USM
EF24-105mm f/4L IS II USM
EF70-200mm f/4L IS II USM
EF-S18-135mm f/3.5-5.6 IS USM
I have seen this before and it does not answer my question. It shows which lenses work with panning mode and panning assist. It does NOT show which cameras have panning assist.
  • You may be correct an panning assist only exists on EOS R3.
I may have seemed a bit rude when I replied to you. Sorry if I did. I appreciate your help.
I use panning assist with my R3 for propeller aircraft in flight. I shoot at slow shutter speeds to capture prop blur, which adds realism to the photo. I find that panning assist helps me get more "keepers" and it's a feature I really like. But it seems that in the Canon community panning assist doesn't get much attention.
Although not quite as detailed as the R3, the cameras listed in John's post have a dumbed down version of "Panning assist" and is referred to as "Panning mode". You can't directly control the SS, but you can tell the camera (AI) how much blur you want, which in turn automatically sets SS depending on the amount of "Effect" you choose. For my R6 II, it's in the "SCN" mode. Probably not something you would want, but it is there albeit not as sophisticated 🙂
Newton
That's good to know, thanks for sharing.
Brian
Thank you for the information. I guess panning assist wasn't a feature that photographers needed or wanted, so Canon discontinued it. That's a bummer, because I find it helpful.
