06-11-2025 10:09 AM
I'm trying to find out if the R3 is the only Canon camera with panning assist. I can't find this feature with any other Canon camera. Keep in mind that panning assist is not the same as panning mode. On some message forums people get those confused. Panning assist uses advanced technology.
I was hoping the R5 II had panning assist, but I don't see it.
06-12-2025 03:48 AM
Yes only the EOS R3 has panning assist, and it is not included even on the EOS R1 or EOS R5 Mark II.
06-11-2025 10:35 AM - edited 06-11-2025 10:37 AM
https://www.canon-europe.com/pro/stories/using-panning-assist-ibis-high-resolution/
https://cam.start.canon/en/H001/supplement_0120.html
The following lenses are compatible with Panning mode and [Panning Assist] (as of March 2025).
This information applies to the cameras noted below.
Type of Lens | Lens Name |
RF lenses | RF24mm F1.8 MACRO IS STM |
RF35mm F1.8 MACRO IS STM | |
RF85mm F2 MACRO IS STM | |
RF100mm F2.8 L MACRO IS USM | |
RF135mm F1.8 L IS USM | |
RF400mm F2.8 L IS USM | |
RF600mm F4 L IS USM | |
RF600mm F11 IS STM | |
RF800mm F5.6 L IS USM | |
RF800mm F11 IS STM | |
RF1200mm F8 L IS USM | |
RF10-20mm F4 L IS STM | |
RF14-35mm F4 L IS USM | |
RF15-30mm F4.5-6.3 IS STM | |
RF15-35mm F2.8 L IS USM | |
RF16-28mm F2.8 IS STM | |
RF24-50mm F4.5-6.3 IS STM | |
RF24-70mm F2.8 L IS USM | |
RF24-105mm F2.8 L IS USM Z | |
RF24-105mm F4 L IS USM | |
RF24-105mm F4-7.1 IS STM | |
RF24-240mm F4-6.3 IS USM | |
RF28-70mm F2.8 IS STM | |
RF70-200mm F2.8 L IS USM | |
RF70-200mm F2.8 L IS USM Z | |
RF70-200mm F4 L IS USM | |
RF100-300mm F2.8 L IS USM | |
RF100-400mm F5.6-8 IS USM | |
RF100-500mm F4.5-7.1 L IS USM | |
RF200-800mm F6.3-9 IS USM | |
RF-S10-18mm F4.5-6.3 IS STM | |
RF-S14-30mm F4-6.3 IS STM PZ | |
RF-S18-45mm F4.5-6.3 IS STM | |
RF-S18-150mm F3.5-6.3 IS STM | |
RF-S55-210mm F5-7.1 IS STM | |
EF lenses | EF85mm f/1.4L IS USM |
EF24-105mm f/4L IS II USM | |
EF70-200mm f/4L IS II USM | |
EF-S18-135mm f/3.5-5.6 IS USM |
06-11-2025 10:44 AM
I have seen this before and it does not answer my question. It shows which lenses work with panning mode and panning assist. It does NOT show which cameras have panning assist.
06-11-2025 11:16 AM - edited 06-11-2025 11:22 AM
06-11-2025 11:35 AM
I may have seemed a bit rude when I replied to you. Sorry if I did. I appreciate your help.
I use panning assist with my R3 for propeller aircraft in flight. I shoot at slow shutter speeds to capture prop blur, which adds realism to the photo. I find that panning assist helps me get more "keepers" and it's a feature I really like. But it seems that in the Canon community panning assist doesn't get much attention.
06-11-2025 01:32 PM
Although not quite as detailed as the R3, the cameras listed in John's post have a dumbed down version of "Panning assist" and is referred to as "Panning mode". You can't directly control the SS, but you can tell the camera (AI) how much blur you want, which in turn automatically sets SS depending on the amount of "Effect" you choose. For my R6 II, it's in the "SCN" mode. Probably not something you would want, but it is there albeit not as sophisticated 🙂
Newton
06-12-2025 12:58 AM
That's good to know, thanks for sharing.
06-12-2025 03:48 AM
06-12-2025 01:31 PM
Thank you for the information. I guess panning assist wasn't a feature that photographers needed or wanted, so Canon discontinued it. That's a bummer, because I find it helpful.
