06-25-2018 11:38 PM
Hello I have observed alot of noise in today shoot. I was shooting in daylight with ISO at 100, i got noise like never before.
Please suggest what can be the reason.
FYI: this is Canon rebel t3i and almost 5 year old.
06-26-2018 11:09 AM
You get a lot of noise, even at ISO 100 when you try to brighten a dark image by more than a stop or so. I suspect that this was the case in your photo. In backlighted case like this, a fill flash will solve the problem. I sometimes bracket the shots and correct in post if the model does not move too much.
06-26-2018 01:29 AM
Well, whenever the exposure is off as far as it is in your sample you will get "noise like never before."
You notice the girl looks fine. Her exposure is correct.
06-26-2018 07:47 AM
@ebiggs1 wrote:Well, whenever the exposure is off as far as it is in your sample you will get "noise like never before."
She is a bit out of focus, though, and that's easily confused with noise. I suspect some camera shake, possibly exacerbated by a slow shutter speed.
06-26-2018 11:02 AM
Bob, the shutter was at 1/3000. I think that was the reason for some grain on the subject and background. Also, what I wear lens which caused a trouble focusing with sunlight.
06-26-2018 11:02 AM
Thank you, I will take this feedback and start working more 🙂
06-26-2018 11:09 AM
06-26-2018 11:12 AM
Here are the setting I used
canon 50mm
F/2.0
1/1500
ISO 100
WB & Exposure at default.
06-26-2018 02:32 PM - edited 06-26-2018 02:33 PM
@dmsrinivas407 wrote:Here are the setting I used
canon 50mm
F/2.0
1/1500
ISO 100
Are you saying you didn't brighten the image at all? Come to think of it, I don't see a lot of noise. The picture is a bit washed out but that is to be expected in such lousy lighting condition
06-26-2018 03:09 PM
Yes, this is RAW image.
06-27-2018 08:21 AM
@diverhank wrote:You get a lot of noise, even at ISO 100 when you try to brighten a dark image by more than a stop or so. I suspect that this was the case in your photo. In backlighted case like this, a fill flash will solve the problem. I sometimes bracket the shots and correct in post if the model does not move too much.
One caution if you do use fill flash: Remember to set the shutter speed to the sync speed. If it's set above the sync speed, the camera will lower it automatically, even if you're in Tv mode. I had that happen to me years ago with a Rebel XTi (400D), and the result was severe overexposure.
