06-03-2023 12:48 AM
H and H+ is grayed out not allowing to set fast shutter speed.
Note: (red tab 1 - duel pixel raw is disabled)
06-03-2023 07:02 AM
@longeye wrote:H and H+ is grayed out not allowing to set fast shutter speed.
Check your shutter mode. If you have not already downloaded a copy of the full User Guide, then I recommend that you do so. Use the link below.
https://www.usa.canon.com/support/p/eos-r6-mark-ii
06-03-2023 09:08 AM
Also what batteries and lenses are you using. If you're using adapted EF lenses. Only certain EF lenses support H+ shooting mode on the EOS R series. Canon has the list of supported lenses in the manual. Also LP-E6NH batteries have to be used to allow H+ shooting to work. The use of older LP-E6 or LP-E6N won't allow H+ shooting.
06-08-2023 09:45 AM
Re H & H+ gray out problem. Thanx for your reply.
Day 1 /OWNER: New R6 Mk2 with Canon 100-500 with Canon supplied battery.
Still unsolved - but will download full user guide as suggested by Waddizzle to search further for answer.
06-08-2023 10:08 AM
@longeye wrote:Re H & H+ gray out problem. Thanx for your reply.
I thought I’d already described the problem to you. Check your shutter mode.
