High speed r6 mark2 problem
longeye
H and H+ is grayed out not allowing to set fast shutter speed.
Note:  (red tab 1 -  duel pixel raw is disabled)
4 REPLIES 4
Waddizzle
Check your shutter mode.  If you have not already downloaded a copy of the full User Guide, then I recommend that you do so.  Use the link below.
https://www.usa.canon.com/support/p/eos-r6-mark-ii
deebatman316
Also what batteries and lenses are you using. If you're using adapted EF lenses. Only certain EF lenses support H+ shooting mode on the EOS R series. Canon has the list of supported lenses in the manual. Also LP-E6NH batteries have to be used to allow H+ shooting to work. The use of older LP-E6 or LP-E6N won't allow H+ shooting.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
Re H & H+ gray out problem.  Thanx for your reply.
Day 1 /OWNER:  New R6 Mk2 with Canon 100-500 with Canon supplied battery.
Still unsolved - but will download full user guide as suggested by Waddizzle to search further for answer.
I thought I’d already described the problem to you.  Check your shutter mode.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
