Help! Rebel EOS T7 is very blurry!
Colestrinity1
Hi there,
I put a lense on my camera then took it off and put the original lense back on then all of a sudden the picture became very blurry. I didn’t change anything from when it previously was working. AF is on and when I tap the shutter to focus it does nothing. Please help! I just bought this camera.
26 REPLIES 26
Tronhard
VIP
VIP
Hi and welcome to the forum
As a first step, I recommend removing the lens and putting it back on, making sure that the lens clicks into place correctly.  It is possible the lens has not quite mounted correctly, in which case the electronics for focus may not be working.
What lens are you trying to put back on?
If this works, please mark as resolved so others know it's sorted, thank you.
cheers, TREVOR
Hi Tronhard,
Thank you for replying to my message. I have taken the lens off and put it back on where it clicks. It still did the same thing. I am using a 18-55 lens. When I put the wide angle on the 18-55 lens it is clear but when I take it off the picture is super blurry. It was perfectly fine before I put the wide lens on originally.
jrhoffman75
It sounds like you are using an auxiliary wide angle “lens” that screws onto the front of your Canon zoom lens. Is that correct?
If so you might have affected the focusing motor of the zoom lens.
https://community.usa.canon.com/t5/EF-RF-Lenses/Autofocus-not-working-18-55mm-lens/td-p/138114
kvbarkley
VIP
VIP
Is LiveView  blurry, or just the view through the viewfinder? Could you have bumped the diopter setting on the viewfinder?
ebiggs1
"Could you have bumped the diopter setting on the viewfinder?"
That would have no effect on the pictures.
EOS 1DX and many lenses.
I think the OP is using “pictures” meaning what he looks at through the viewfinder. I base that on his statement that when he actuates the shutter nothing happens. Shutter won’t fire if focus isn’t achieved.
Tronhard
VIP
VIP
Exactly what model of 18-55 lens are you using?  Is it the 18-55 1:3.5-5.6 II lens (see the front of the lens for this).
If it is, have you manually focused the lens -
and if you did was the AF/MF button turned off at the time?
cheers, TREVOR
ebiggs1
"I put a lense on my camera then took it off ..."  Was this a different lens?  "... put the original lense back on ..."
 It sounds like it. The camera must have worked.
"I didn’t change anything from when it previously was working."
The OP indicated it did work at one time? If the OP is screwing an add-on lens attachment that could be the reason and mostly like is.
ebiggs1
It's difficult to diagnose these things with ambiguous info. A clear accounting of the gear, all of it, and settings, along with a clear explanation of the issue would be helpful.
Is it just the VF? Is it both the VF and LV or is it actual pictures?
