05-29-2022 03:27 PM
My camra is skipping threw the camra modes on the spin wheel. How do i fix this problem?
05-29-2022 03:35 PM - edited 05-29-2022 05:01 PM
Hi, and welcome to the forum:
So we can better help you, can you please clarify: do you mean your camera is cycling through the shooting modes (Av, Tv, M etc.)?
Please indicate from the diagram below, which number applies to the wheel to which your refer:
05-29-2022 06:34 PM
yes its cycling through the shooting modes. #5
05-30-2022 05:27 AM
Hi again: I must admit I am a bit confused as to the specific issue...
The wheel you identified as #5 is the function that is actually supposed to allow you to choose different modes whenever the dial is rotated - as per your manual on P67.
Can you possibly be a bit more specific as to what triggers the modes to cycle? For example:
Is the issue that you are rotating this accidentally?
Are the modes changing without you rotating the dial?
Are the modes changing on a continuous basis, rather than one click to go from one to the next?
Once you select a mode then press the <SET> button - #12 in the diagram and that should confirm that you want that mode.
