Canon T8I SCN Mode
kujhawk1978
On my Canion T8i, I cannot select the SCN mode, it is greyed out.
I've tried resetting the camera to factory settings, doesn't work
kujhawk1978,
I'm afraid Demetrius is right. I think you have a technological problem. You aren't doing anything wrong, and no settings change you could make will fix your problem.
It's time for a repair job.
Steve Thomas
15 REPLIES 15
deebatman316
Will the mode dial turn to that position or not. Please clarify the problem.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 85mm F/1.8 USM
Yes, the mode dial turns to that position but what shows is the P mode
kujhawk1978,
The SCN indicatior and the P indicator are on opposite sides of the dial.
The little indicator that shows what Mode you are in is on the left hand side closest to the viewfinder as you look down at the dial from above. Try turning your dial so that SCN is in the 9:00 o'clock position as you look down at the dial from above.
Steve Thomas
Do the other modes report correctly when the mode is turned to them.
-Demetrius
Steve
Thanx, the SCN is at the 9 position
The SCN and M are greyed out and when I turn the mode dial to those, no deal. The others work fine.
What you set the mode dial to doesn't reflect what the camera's LCD screen shows. Take a picture with the mode dial to SCN & M Mode and a picture of the LCD screen.
-Demetrius
M  mode
SCN mode
