07-04-2014 05:15 PM
07-04-2014 06:21 PM - edited 07-04-2014 06:22 PM
07-05-2014 02:52 AM
07-05-2014 08:42 AM
I agree with Tim and guess it is a ML issue. And another reason I don't use it or recommend anyone else use it.
07-14-2018 03:02 PM
07-15-2018 01:07 PM
Are you using ML, also? If ML causes a major problem it turns the camera into a brick. It can not be undone. It has to go to Canon for service.
If you are not using ML and have tried all the easy stiff and recommended stuff, your camera probably needs service too.
Call 1 (800) 652-2666
07-15-2018 10:27 PM
07-16-2018 08:52 AM
You did not answer.
07-16-2018 09:19 AM
You should spell out "Magic Lantern"
Have you tried a new card and formatted it in the camera? It sounds like your card is fragmented and it takes a long time to write your images.
07-16-2018 12:12 PM
