01-22-2024
10:14 PM
08:39 AM
Arthur
I am getting a flashing red light on the rear lower right of the camera. This is new not sure what is happening
01-23-2024 10:08 AM
Any possibility you engaged the self timer feature?
01-22-2024 10:17 PM - edited 08-13-2024 11:46 PM
Hi and welcome to the forum:
What camera are you using and when does this happen specifically, please? Is it for a few moments, or does it go on for a long time? It is quite normal for the red light on the back right to flash as the camera is turned on as it boots up and reads the card. That will also happen when reading and writing to a card.
01-23-2024 07:58 AM
I have EOS R6. The light flashes red for a while. I press the shutter and it continues to flash and takes delayed picture
01-23-2024 09:21 AM
Usually it is a bad/full SD card.
You might want to try another one. Is this a full size card or micro with adapter? Micro Cards with adapters often have issues.
01-23-2024 10:08 AM
01-23-2024 10:17 AM
Lets be clear, you are talking about the light marked "10" here, right?
01-24-2024 01:24 PM
I have 2 full size cards purchased in November and I have only taken about 90 practice photos
01-24-2024 01:25 PM
I will check when I get home. Thanks
01-24-2024 01:44 PM
Backup the pictures and low level format then in camera.
