08-22-2024
11:06 AM
11:53 AM
Hello, I purchased my Canon EOS Rebel T7 back in August 2020. I didn't begin using it until May 2022 when I became interested in wildlife (specifically birds) photography. It's been a great camera until this point. Recently, I had the LCD screen suddenly go blank. It appeared the camera was still taking photos, although it was beeping. I read a suggestion in the forum to do a hard reset. It miraculously cured the problem. I used the camera a few times since without issue. Suddenly today, the LCD screen went black again. Any idea what's going on?
03-06-2025 06:16 PM
Hello, it has been several months, and I've been using my Canon Rebel T7 without further issue. Initially, I replaced the battery which was probably due. As well, I had done a hard reset. Ultimately, I found the resolve was to disable the "Auto Power Off" under Tab 2. With everything, I am happy to report that it's working like a charm.
03-07-2025 10:50 AM
Pretty old thread to respond to but.....🤔
"I even tried updating to the latest firmware and it still has the issue."
Besides not ever going to help it would be a real trick to do if the LCD screen went "blank". Even if you have a working LCD screen updating the FW on a malfunctioning camera is a bad idea a very bad idea.
03-07-2025 12:06 PM
I found that I can temporarily get the screen to display by holding down the shutter release button while turning on the camera. Then I can access the menu. But as soon as you press the shutter release button again (even a half way press), the screen goes blank again.
