EOS Rebel T6 Missing Images - Help please
Tmag23
Im not sure if this was asked or not. I have a  EOS REBEL T6  & Today when i did my daughter prom pics everything was fine (so Iy thought) i turned camera off for a min and when i turned it back on all my pics but the first one was gone but When I took second shots at the school ALL pics are there. Any help !  Not showing anything on camera or in different files. Wont load on my laptop. Does this mean all the pics are gone ?
22 REPLIES 22
Yes, Rick - I thimk it is a cae of not being aware of the subtlties of the different for mats.
I'm pretty much where you are in this.
cheers, TREVOR
@Trevor,
True indeed.  Hoping for positive outcome. I guess we'll see.  Cheers to you my friend.
Thank you. Ive always used sandisk sd for all my cameras ive never had issue till now and im not sure what happen. Imma try recovery and see but i feel they are already gone. I may just have to redo pics 😕   thank you everyone for the advice & recommendations. I will try all of them and see .
@Tmag23,
There's nothing wrong with the SanDisk brand.  These are one of the manufacturers we recommend most due to their reliability and performance.  The issue is with the type of card.
You need to use a standard full-size card, one that doesn't use the adapted microSD.
Oh im sorry i had misread that. Ill definitely get full size but seems pics are gone unfortunately. I cant seem to find em anywhere.
ebiggs1
This is the best advice you have gotten from this thread,....
"I would also look into multiple smaller 32GB Class 10 SD Cards. DO NOT use 1 large SD Card to store all of your pictures. If the card were to fail you would lose all of your pictures. Using multiple smaller SD Cards prevents this from happening."
........beside not using micro-SD that is. Also keep in mind cameras are not a photo storage devices like some folks do on their iphones. Depending on how important the photos are you can send the micro-SD to SanDisk for them to try and recover them. They can do a lot better than the software but it isn't free.
"When I took second shots at the school ALL pics are there."
If you were able to review the photos after you took them I.E. at the school later on, then the photos are there. Don't use the micro-SD any more before you send it to SanDisk or try the recovery software on it.
EOS 1DX and many lenses.
BurnUnit
Whiz
Whiz
I would try putting your micro SD card in a different full sized adapter if you have one. Or borrow or buy a different adapter. And try reading it on a different PC or with an external card reader if you haven't done so already.
Most memory card related problems in the forum are due to using Micro SD Cards in an adapter. The camera was designed for Full Sized SD Cards. If Canon designed the camera to be used with Micro SD Cards. The camera would accept them directly without an adapter. Using an adapter creates another mechanical interface which could lead to problems. The other common memory card problem is using too large of an SD Card that an older camera can't support. Don't buy cheap SD Cards either.This picture was found right here in the forums. Warning other people NOT to use cheap SD Cards.This picture was found right here in the forums. Warning other people NOT to use cheap SD Cards.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
Tmag23
Thank you everyone for advise. My SD CARD is a full size I'm sorry I thought it was mini with adapter.  Im going to try to recover photos first not sure if will be able to but won't hurt to try. Im not sure what happen ive never had it happen before.  I dont never leave photos on card when I am done taking them I always put them directly on my laptop for free up space on card. But I guess we shall see.
Thank you
ebiggs1
I would buy an external SD card reader. They are not expensive you can get one at Walmart or Amazon. If you are going to try recovery software don't do anything to the SD for now.  Wait until you get the SD reader. Wait until you get the recovery software and install it on your laptop.  Above all don't delete anything or format the SD card.
Repeat.............
