05-20-2023
09:50 PM
08:16 AM
Im not sure if this was asked or not. I have a EOS REBEL T6 & Today when i did my daughter prom pics everything was fine (so Iy thought) i turned camera off for a min and when i turned it back on all my pics but the first one was gone but When I took second shots at the school ALL pics are there. Any help ! Not showing anything on camera or in different files. Wont load on my laptop. Does this mean all the pics are gone ?
05-23-2023 03:50 PM
Did you format the card before using it for the first time? Always format a new card.
05-23-2023 03:58 PM - edited 05-23-2023 04:01 PM
Personally, I format the card on first use and after I have downloaded the images from the card. I do so on the camera, not on a computer or other device - that makes sure the format matches the camera's file system
I recommend the following procedure in dealing with cards:
1. Before first use, format the card on the camera
2. After shooting the images you want, remove the card from the camera, connect it to a computer (Ebiggs1 is correct a USB reader is the simplest) and download the images to your hard disc. Make sure the images are readable on the computer. Don't just pull the card out of the reader when done - if using a Windows machine, use the Eject feature (right-click on the icon for the card to see this option). If the card is still in use you will get a message that it's not safe to do so, in which case close any programs that might be using the card before having another go.
3. Remove the card, put it back in the camera and format it, ready for the next shoot.
It is not a good idea to just delete all files. The way that deleting works is that it simply removes the first character in the file name and that tells the camera file system the space is now available. The problem potentially creates is the accumulation of damaged file entries that will create a risk of a read/ write error.
I hope this helps
05-24-2023 07:27 AM
I use to fomate everytime then was told I didn't have to. So this time i only fomated once when i got SD card in February. I did her homecoming pictures all did amazing. Got them on computer. Now prom took one pic of getting my focuses n lenses together & start my shoot everything seemed fine all on there. Turned camera off to drive 3.5 mins up road to school turned camera back on & took few pictures at the school went to look through pictures and The pictures i just took was on there but the ones before I turned camera off is gone.
