07-21-2016
01:28 PM
08:49 AM
I just got this error on my T5. When I try to take a picture, it says: "Card cannot be accessed. Reinsert/change card or format card with camera." re-inserted but no luck.
So, I try to format the card from the camera menu settings, and it says "Cannot format. Change card."
I even tried re-formatting the cards on my computer, but still no luck. the card works on other cameras, so it's not the card.
I have used this card in the camera before and never had a problem, this just happened all of the sudden.
PLease help. My camera is only 4 months old.
02-24-2018 06:27 PM
My camera stop reading my card. At first I thought it was the card but I put in an old card and it's still not working. It just says no card. Please help!!!!
05-31-2018 05:52 PM
Hello Danielle4,
We recommend trying a completely different card in the camera. Please make sure that you format the card in the camera prior to use. This will help you determine if the issue is within the card or the camera.
08-13-2018 12:19 AM
08-13-2018 03:52 AM
@Jkm wrote:
Hi, ok I had the same issue with my canon t2i and figured it out, it was my fault. I bought a 32gb card and, I got an error message saying format or replace card. When I tried to format the card, my camera wouldn't let me. I tried to format it on my computer but, I couldn't do that either. After a good while trying to figure it out, I realized the card I bought came in a package with a much smaller tiny card. I figured that the smaller card is for my phone and, I don't really need it so, I just tossed it in my drawer. I realized much later that there was that slit on the bottom of my 32gb card. I figured it was just a part for your fingers to grab on to to pull it out of your camera or whatever. Well...that much smaller tiny card that came in the package with my sd card, that tiny card fit into that slit on the bottom of my sd card and, as soon as I put the sd card in my camera..perfect..over 4000 shots available and no need to format. So, I hope this helps someone out....
Two things:
1. MicroSD cards are not recommended for use in Canon DSLRs. The adapters are very unreliable.
2. The memory card really does require a low level format by the camera.
The microSD memory cards really should only be used in devices that use them directly, without an adapter. If you look up your camera’s instruction manual, I am sure that you will see “SD” and “SDHC” cards as being suitable for use. You will not see “SDXC” or “microSD” listed as a compatible type of memory card.
Memory cards are tested for speed and functionality during production. While it may seem as if the card has been pre-formatted, it has not. What you are seeing is residue from production testing. The formatting may not be complete, either. The production testing formatting residue needs to be completely wiped away by performing a “low level format” in your camera.
08-13-2018 07:14 AM
08-16-2018 11:08 AM
What you bought is a micro-SD card (yes, the type of card used in cell phones), together with an adapter that makes it usable in place of a full-size SD card. After you discarded the micro-SD card, you were trying to use the adapter as though it were a card; so of course it didn't work.
Now that you're using the card and the adapter as they were intended to be used, things are working. But you may not be entirely out of the woods yet. Many users have found that combination unreliable, and having a card fail during an important photo shoot is the last thing you want to have happen. (Actually, it's the next-to-last thing. The last thing is not to discover the problem until you're back at your computer trying to edit the pictures you didn't take.)
So the bottom line is that the safest course of action is to throw both the adapter ind the micro card in the drawer and get a proper SD card. Or maybe you can use the micro card in your phone. ![]()
08-16-2018 12:33 PM
09-05-2018 06:28 PM
Hello, I had this exact same problem! I have two SD cards (one a normal SD and the other one is a Micro SD inside an adapter)!
All I did is clean the "golden" pins (I'm not sure how you call them)!!! Both of them were a bit "dirty" from overuse, once I cleaned them they worked perfectly
Hope this would help
07-31-2019 04:11 PM
08-07-2019 08:38 AM - edited 08-07-2019 08:39 AM
If you have photos on the Cfast card, as recommended above first try to read them with your Cfast card reader and if that doesn't work AND they are important photos then check with the card manufacturer to see if they have recommended recovery software.
When I was primarily using my 1D Mark II I would transfer photos by putting its SD card into a reader. But now that my 1DX Mark II and 1DX are what I use most of the time I transfer images via the Ethernet port. If you are using CF and Cfast cards with a card reader, make sure that you are using very good quality cards from a reputable retailer and be very careful inserting those cards because CF and Cfast socket pins are fragile compared to many other interface systems and easy to bend.
NOTE: there are a lot of lower end Cfast cards that use "CF class" memory and although these fit the Cfast port they only provide CF level performance. Also, memory cards are one of the most counterfeited products in the world and what you often get from large online merchants is a fake which may have both electronic and physical/mechanical deficiencies. After getting some counterfeits from the very large online retailer, I now buy all of my memory cards from B&H and Adorama.
Rodger
