EOS RP Bulb Timer and issues with remote control
tbar23
I have been using my EOS RP for astrophotography with the Bulb timer and a 2s delay shutter release. So I'll set my desired Bulb timer (usually 60 - 120 sec), press the shutter release to start the 2 s delay, and then I get the desired exposure time. As the weather gets colder, I would like to use the Canon app on my phone to release the shutter (I can probably get rid of the 2 sec delay), but I have had lots of trouble keeping the Bulb timer delay enabled while using either the bluetooth connection or the WiFi connection to my camera.
The behavior is somewhat erratic - sometimes I will get the programmed bulb timer, sometimes I will get no timer at all and sometimes I will get a "typical bulb" mode where the first press of the app shutter starts exposing and the second press stops the exposure.
I have also noticed that when I try to exit app control, I have to power the camera on/off before the physical shutter release button will start working again.
Has anyone encountered these issues.
Ideally, I would like to program a series of exposures ... say 20 shots of 90 sec each. Is that possible?
jrhoffman75
Welcome to the forum.
I don't have an RP (I have a DSLR) but I do a lot of astrophotography.
My camera doesn't have a built-in timer option. It does have the ability to link with the canon IOS app; it has never worked sucessfully for me.
I use this for my shooting. (I use the more expensive option since I need the N3 connector, but from what I saw in the manual your cmaera just needs the E3 pin connector.) Works great and can work wired or wirelessly.
4 REPLIES 4
jrhoffman75
Thanks, John. I wondered if I would need to go this way. I did experiment a little bit last night, and I found that if I eliminated the 2s delay, the app worked a bit better. Howeer, I want consistent operations, so I'll check out the remote controller options.
Can you program a sequence of exposures with that device?
I see that you are a fellow New Englander - though you are closer to some nice dark skies than I am in Andover, MA!
Hi.
I am lucky here that we have good access to dark skies.
Yes, you can program duration and number of exposures. Or just use it as a remote release.
I ended up buying the TW-283 and it works well.
Holiday
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R5C - Version 1.1.1.1
EOS C80 - Version 1.0.3.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
