12-26-2023
09:40 PM
08:39 AM
I can't get to Expand AF area: Around.
The cursor jumps from Expand AF area to Flexible Zone AF 1
What's the solution?
12-26-2023 10:23 PM
I really, really want to help you, but this is like getting blood out of a stone. What about all the other focus settings?
12-26-2023 10:25 PM
The other focus settings are good.
12-26-2023 10:25 PM
OK, knowing that you have the R8 helps a lot. This is the first camera that I have seen the term Around as a description for a focus area. So, we can now proceed further. Let me read the relevant material from the guide and get back to you. In the meantime, it would be really helpful to have an idea of the objects you are shooting. Static, moving, eye tracking on or off.
12-26-2023 10:28 PM
Have you checked the User Guide in the AF Range section?
I note that if you have Servo focus turned on, first it will use a Point AF... Is that the experience to which you are referring?
12-26-2023 10:28 PM
Subject: Static
The term Around is where it says in the manual.
12-26-2023 10:37 PM
I use "One Shot" mode.
The cursor jumps from Expand AF area (3rd from the left) to Flexible Zone AF1 (%th from the left)
12-26-2023 10:38 PM
I found another reference to this autofocus method with a more detailed explanation of how it works:
This was why I was asking what other autofocus features were set.
12-26-2023 10:56 PM
I think I understand what your are trying to ask...
Are you saying that when you go to select Expand AF Area, within that menu, it goes to Flexible Zone AF1. That is not so much that it does it when you are shooting, as when you are trying to set up the focus options in the menu?
12-26-2023 11:01 PM
My question is: why it by passed the Around option? and how can I get it back?
12-26-2023 11:10 PM
OK, I think I now understand your issue. If it's simply that the option for Around is not available then I suggest going to the Purple Focus menu, Tab 4, 2nd from the top is Limit AF Areas. Check to see if the Around option and any other options are not ticked. If it is not, then that is your issue. If you want to remove options that you are sure you will not use, then this is the place to do it.
When you first posed the question, I understood it as switching from Around to the other Area buttons when you were actually trying to actively focus on a subject.
Does this seem to be the issue for you?
