Canon EOS 400D memory light flashing quickly.
BrendanC123
I have a Canon EOS 400D and when I leave it for a few seconds, the screen goes blank and the memory access light will flash very quickly. What do I do about this?
7 REPLIES 7
deebatman316
What kind of memory card is this. Full Sized or a Micro SD Card in an adapter. Discontinue the use of adapted Micro SD Cards. Also what size (GB) of the SD Card. Your camera doesn’t work with (SDXC) SD Cards those cards are 64GBs or larger. Use a smaller SDHC or 32GB or smaller SD Cards those cards.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
It's a CF Card
Have you tried a different CF Card to rule it out. Also what size is it.
-Demetrius
I have no other CF cards. It's a normal sized CF card.
What is the capacity size 4GB, 8GB, 16GB etc.
-Demetrius
32GB CF card.
Did this card previously work in the camera. Older cameras typically don’t work with large CF cards. I use 4GB & 8GB CF Cards in the my old EOS 40D and never have problems. Bigger cards don’t work well because the camera wasn’t designed to be used with them.
-Demetrius
