01-16-2024
02:06 PM
02:07 PM
My camera will not update the firmware 1.30. It just restates the camera without updating
01-17-2024 12:18 PM
It finally updated! Thanks all! I removed the battery grip, put the FIR. on both extreme Pro cards. And now this time it is updating for some reason; I had already tried this before.Anyway, Happy that it finally worked.
01-16-2024 02:25 PM
How are you updating the firmware? With an SD card? Or via software on a computer?
01-16-2024 02:28 PM
SD card
01-16-2024 02:39 PM
Is the file on your SD card using an .FIR extension?
01-16-2024 02:50 PM
I've updated my other cameras without incident, this new R6ii will not update.
01-16-2024 02:53 PM
What mode do you have the camera in? And when does the camera restart? At the point of powering it on, or are you able to navigate to the Firmware update menu, and select OK?
01-16-2024 03:10 PM
P mode. It will go to the screen asking me if I want to update the camera to 1.3.0. It then hesitates and then will restart.
01-16-2024 07:35 PM
@lazya wrote:P mode. It will go to the screen asking me if I want to update the camera to 1.3.0. It then hesitates and then will restart.
While it's hesitating, do you have a grayed out "OK" selection option to the right of Cancel? If so, tap OK (even though it's gray).
Newton
01-16-2024 03:16 PM
I've tried 3 different cards. I think I will wait a week when I have more time to troubleshoot this.
Thank you for your time Ricky
01-16-2024 03:40 PM
For SD cards, be sure to be using full-sized ones from reputable brands. Micro-sized cards that require an adapter can lead to all kinds of issues.
