07-02-2025
06:26 PM
09:26 AM
Just got an r6, markii and the touch and drag works in the viewfinder, but not the lcd screen. What settings do I change to get it to work on the screen too?
07-03-2025 03:53 PM - edited 07-03-2025 03:53 PM
Thank you for the reply, unfortunately the touch shutter is disabled and it still does not work
07-03-2025 09:42 PM
When you are looking at the LCD there is is no need to drag; just touch the object you want to focus on.
07-04-2025 05:06 AM
Is the touchscreen disabled in the camera menu? It's in the "Wrench 5" menu, Touch control it needs to be set to standard or sensitive. If touch control is enabled then check to make sure the camera power switch is set to the ON position, not the LOCK position. This is because it is possible to lock the touch screen as part of the lock switch setting.
