09-24-2023
01:04 PM
09:41 AM
Just bought camera and when off components rattle loudly at the easiest tilt. I’ve read it’s IBIS. It quiets down once turned on but still hear it.
I’ve read the 6 has noise but doesn’t sound like a broken cheap toy like the mark2.
May I get some feedback on this plz?
any adjustments to make anywhere within camera to stop this rattle? Thanks
09-24-2023 01:34 PM
This is the IBIS. In body image stabilization. Completely normal. Nothing to worry about.
09-24-2023 01:46 PM
Thx.
the noise is incredibly loud . And I never have my camera turned on 100% of the time which means in quiet places it will rattle. I use to shoot on set stills and for a Mirrorless camera it’s awful to have this rattle at any time. Very bizarre
09-24-2023 01:49 PM
I understand. I assure you its 100% normal. It can sound disconcerting, but there is nothing to worry about.
09-24-2023 01:57 PM
Do you know of Any setting internally that will help to quiet it down?
thx for your help
09-24-2023 02:44 PM - edited 09-24-2023 02:52 PM
I have the R6 Mark II, but I have yet to notice any sort of rattle. I think I did enable the setting that covers the sensor when you remove a lens. It might also cover the sensor on power down. I do not recall if I disabled Continuous AF or not. It will be a few hours before I can review my settings.
I dunno. I see no point in trying to make my camera rattle.
09-24-2023 05:47 PM - edited 09-24-2023 07:01 PM
KK2023,
IBIS is only active when the camera is on. When its off, its possible for the sensor to rattle a bit. Its well documented on the web, you've read about it. I've not heard of a setting that can diminish this sound. IBIS is active when the power is on and not when its off.
Newer lenses can also make a similar noise. This is how the lens is designed. Like the body, its lens group "floats" and the sound it creates when the IS is not active "energized" can sound like a rattle.
Image credit Newton aka FloridaDrafter
You can use Google to read about it, and watch videos on Youtube. Its normally occurring and nothing to worry about.
Random example:
My RF 100-400 does the same thing if I shake it. Sounds like a single marble baby rattle. It takes great photos. 😉
09-24-2023 06:24 PM
My rattle sounds the same. Intense .
have had a few cameras and none have rattled like this! I won’t worry about it but wow it’s annoying and leaves you with less confidence about the unit.
09-24-2023 07:17 PM - edited 09-24-2023 07:18 PM
I truly understand. When I took my 100-400 out of its box I was like "what the"? Suddenly visions of UPS truck loaders using it for warehouse football went through my mind. I shined a flashlight into thinking there was going to be a cracked or shattered mess. Nope. Then I mounted it and zoomed out, then back it. Then I squeezed off a shot. Perfect.
09-24-2023 08:43 PM - edited 09-24-2023 09:00 PM
It's mainly the shutter curtains that are making the loud rattling sound you hear in the R6 II body. Yes, R cameras IBIS and the RF lenses floating IS component move around a bit and are slightly audible until in use, but on their own, not that bad.
Newton
