07-27-2024
05:18 PM
05:45 PM
Tiffany
I have an R6 Mark II that I got about 6 months ago, and I am an amateur-level photographer. I shoot in manual most of the time with auto ISO and exposure compensation if I need it. I have the ISO capped at 12800. Today, I volunteered to shoot people at an event, so I set the camera to aperture priority so I could set my f stop and leave it since I was shooting them in front of a prop. I used my Canon EF mount (with adapter) 24-105 lens. My ISO was also on auto. My friend, who also has a Canon mirrorless (don't know which one) was there as well, with a Canon 70-300 EF mount lens. She set hers up the same way as I did. I noticed that my camera chose a very fast shutter speed combined with a high ISO. Shooting the same scene, her camera chose shutter speeds of around 1/200 with a much lower ISO. Why is that? Is there some setting I don't yet know about that's doing that? This has happened once before but I didn't think much of it then because I didn't have another photographer with me where we could compare settings. It seems like the shutter speed and ISO are competing with one another. What's going on? I'd greatly appreciate your help!
Sherri
07-28-2024 11:20 AM
Thank you. It very well could be operator error. I'm new to the camera, so I'm still learning it slowly. I've never done this type of shoot before and as I said, I almost always shoot in manual so I have control. I will certainly take your advice. Again, thank you.
07-28-2024 04:34 AM
It sounds like you might have exposure compensation set. This is a feature that allows proper exposure if you are shooting a scene that is predominantly darker or lighter than average. An example of how this feature is used isn if you were shooting a person in a white ski suit on a snow covered mountain. If you let the auto exposure set the scene normally the snow and the person would come out as grey rather than white. the image would be under exposed. To adjust for this your camera has an exposure compensation function that allows you to adjust the default exposure up or down by a few stops. I would check to see if this is mis adjusted.
07-28-2024 08:44 AM
We both had exposure compensation set to the same value -2/3 of a stop, and you would think the camera would slow down the shutter speed to compensate.
07-28-2024 08:43 AM
Sherri,
In your settings for the ISO range, or maximum ISO, is there also a setting for minimum shutter speed?
Steve Thomas
07-28-2024 08:49 AM
Yes it does. I just found it. It was set to manual 1" which when I look at it it says 1/1000, then below that is 1/30. I don't know what any of this means. There's also an auto setting. Should it be set to that?
07-28-2024 10:16 AM
Sherri.
Yes, I think so. Set it to Auto.
I think that's why your camera is using a minimum of 1/1000ss and kicking your ISO up so high.
Steve Thomas
07-28-2024 11:24 AM
Intuitively I thought that meant the highest would be 1/1000 and the lowest would be 1/30. I don't know how it got set to that, since I never set it, but I will change it to auto and see what happens. Thank you.
07-28-2024 11:07 AM
If not already done, it might be helpful to review the R62's user guide.
Canon : Product Manual : EOS R6 Mark II (start.canon)
Additionally, until a better understanding of the camera function's are understood, I would refrain from making changes to it's menus while you are learning about the camera's features.
Consider resetting the camera's main and custom functions. Establish a baseline for exposure and start from there. Avoid extremes.
It would also be helpful if you could post some RAW photos with EXIF data. We can evaluate these for you. You can use a sharing service to facilitate this. OneDrive, DropBox, GoogleDrive, etc.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
07-28-2024 11:23 AM
OK. I don't have any custom functions set up yet. And I don't have much in the way of settings outside of the defaults, except BBF and things like AI Focus, single point focus.
