10-25-2025
09:00 PM
10:48 AM
Hi everyone,
I recently bought a used Canon R50 from MPB that was listed as spare parts due to being unable to read SD cards. I decided to take a chance on it, but I’m running into the same issue every time I insert an SD card, I get the message:
When I turn on the camera: "Card cannot be accessed. Reinsert/change card or format with camera.”
When I try to format card via camera: “Cannot format. Change card."
Here’s what I’ve already tried so far:
Re-formatted SD cards correctly on my computer (exFAT).
Tested multiple cards, including a full-size SanDisk Extreme Pro 128GB and a microSD 32GB with adapter.
Verified that the lock switch isn’t engaged.
Cleaned the SD card contacts with isopropyl alcohol.
Updated the camera’s firmware to the latest version.
Performed a full camera reset.
Despite all that, the camera still won’t recognize or format any card. I’m starting to think it might be a hardware issue with the SD card reader itself.
Has anyone experienced this with the R50 or similar Canon mirrorless models? Is it typically a bent pin or a full card-slot board failure? Any guidance or repair cost estimates would be appreciated.
10-25-2025 10:34 PM
I've seen both things you mentioned cause card read/formatting issues. If you were hoping for a functioning camera I'd return it. Standard recommendation is don't start with a broken camera.
You can grab a refurbished R50 and lens here.
https://www.usa.canon.com/shop/p/refurbished-eos-r50-body-1
10-26-2025 05:52 PM
From what I have heard is that MPB does test the products they sell and they listed this as spare parts. I would think if they thought a repair was reasonably priced where they could still sell it with a profit they would have done so. If they will take a return I would return it, or find another parts camera if you think you can fix it.
