EOS R5 Mark II time lapse exposure options similar to EOS R6 Mark II?
Aerobatpj
I am thinking of upgrading my R6 mk11 to the R5 mk11 for better definition. However I use time lapse function quite often and a good feature of the R6 is that you can set the exposure for each seperate frame to get even results from dawn to dusk. I have a 5D mkiv and the time lapse on this sets the exposure on the first frame and does not change. The question I have is does the R5 have the same single frame exposure capabilities as R6 ?
stevet1
Aerobatpj,
According to the product manual, you can. See Item# 7 here:
https://cam.start.canon/en/C017/manual/html/UG-03_Shooting-2_0150.html
Steve Thomas
2 REPLIES 2
stevet1
Aerobatpj,
Steve Thomas
foyeg95412
Hello,
The R5 doesn't have the same automatic exposure adjustment per frame as the R6. The exposure is fixed to the first frame and doesn't change during the time-lapse. The R6 allows for dynamic exposure adjustments across frames, which is great for dawn-to-dusk shoots. If that’s a crucial feature for you, the R6 might be the better choice.
Best Regard,
foy
