10-19-2024
08:33 AM
08:38 AM
10-22-2024 03:59 AM - edited 10-22-2024 07:10 AM
Do you have auto bracketing cancel set to ON (the default) in the custom functions? If so then try turning it off.
https://cam.start.canon/en/C017/manual/html/UG-09_Custom_0030.html
I don't have the EOS R5 Mark II but all the other cameras I tried work in the same way. EOS R10, EOS R6, EOS R6 Mark II.
Additionally flash exposure bracketing is a function of the Speedlite, not the camera body even though it can be set from the camera menus. I checked the Speedlite 600EX-RT II and there is a custom function in the menu to also stop the flash bracketing from being reset on power off. It's the same in other Speedlites that support FEB. Here's the page in the Speedlite EL-5 manual as an example C.Fn-03
https://cam.start.canon/en/A006/manual/html/UG-05_Custom_0030.html
UPDATE: I now realise the question was about both AEB and focus bracketing. My answer applies for AEB only. There's no similar capability to retain the focus bracketing settings when the camera is powered off.
10-21-2024 08:01 PM
Hello mccrossan,
You are correct in that those two features will be disabled once the camera is powered off unfortunately. The workaround that you have found is the best route to access those things quickly at this point.
10-21-2024 08:48 PM
Or, you could add them to a custom user menu.
10-27-2024 06:50 AM
Thanks. That worked. It makes no sense to me that I can't do the same with focus bracketing.
