EOS R5 Battery Storage & Firmware Updates
Ettannen
just purchased a EOS R5, Is it adviseable to remove the  battery when the camera will be in extended storage ? also, do I need to do all firmware up dates, even if they are for a feature that I do not use ?
6 REPLIES 6
Peter
Li-Ion should be stored 40-50% in a cool and dry place if you don't use camera for a while.
jaewoosong
Rising Star
Rising Star
ideally.  leaving in the camera will have a slight draw as the top LCD still gets powered.  I have the R5 grip and I just remove the grip (with batteries still in grip).
-jaewoo
Rebel XT, 7D, 5Dm3, 5DmIV (current), EOS R, EOS R5 (current), R50V (current)
Michaelhunt
It is always a good practice to remove the batteries from your camera when it is not being used. If you leave the batteries in your cameras unused. Tgr Batteries will get discharged automatically, not only that if if finds little moisture not only your batteries will get rusted. Your camera will be adversely affected which may lead to failure of internal chios(IC). Remember that rechargeable batteries grow less powerful the more you use them. It's advisable to keep a spare at hand.  HEB Partner
I find that the R5 in particular runs batteries down fairly quickly if you're not using it, like for days to weeks; so I take them out.
As for firmware updates -- you don't ever need to apply a firmware update.  Personally I prefer to keep all my kit up to date with firmware, although it's much less of a priority if I don't see anything interesting in the update description.  However:
  • the release notes will never list all the big bug fixes that might be in there, so staying up to date will usually result in a general improvment in quality and reliability
  • it's always pssible that a new firmware release will break something
So... I guess I would recommend waiting a little, after new firmware comes out, to see if the eager beavers (like me) report any issues.  But then, yes, my approach would be to update.
@Ettannen,
To add, I'm in agreement with the guys regarding removing batteries and storage when not using the camera for extended periods.  Better for the camera and you.
Firmware:
At this point the latest available FW for the R5 includes some pretty significant feature and performance updates.
If your camera is using FW v1.5.2 or earlier, I would upgrade to v1.6.0 (at minimum) or v1.7.0
The new additions in v1.6.0 were significant.  You can go straight to v1.7.0 as well, regardless of the version you are running now.
ebiggs1
Simple answer, yes to number one and no to number two.
EOS 1DX and many lenses.
