06-21-2022 12:45 PM
Hey everyone,
I bought an R5 six months ago and recently it started misfiring while using strobes. It's happened with Profoto, Godox and Elinchrom so I know it's not the lights. Every 10-15 photos I take, the focusing box on the back screen stays white instead of green and the shutter audibly slows and sounds kind of crunchy, like it's skipping a beat. The photos turn out dark even though the strobes go off, so it's like the camera isn't taking in light fast enough. This will last about 5 photos or so, then go back to working properly. I also use a Commlite mount adaptor for my lenses so not sure if it's that or the camera.
Anyone else struggle with this or have a solution?
06-21-2022 04:19 PM
It could be the adapter. If you switch the lens to MF and the issue persists, then there could be an issue associated with the camera. Ditto for an all manual lens. If the issue goes away when manual focusing, then there could be an issue associated with the third party mount adapter.
06-22-2022 01:11 AM
Greetings marlaolivia,
I would agree with Waddizzle on the information they've provided for you to test on your end. We would suggest to test a Canon RF lens with the camera. If possible, please also test a Canon Speedlite flash since it appears that you are using third party flashes and strobes. This will help in determining if there may be an issue with the camera itself.
01-11-2023 02:00 PM
Hey I’m sure you probably got this problem fixed by now, but I think the problem was the hot shoe was loose. It’s a common problem with older R5s when they first released. I’m currently having the same problem and it makes my flash misfire as it’s not fully connected from it being loose. It can cause problems where the flash doesn’t go off, or the flash is not synced and you will see a strip of black in your photos.
