EOS R5 Quick Control Metering Setting
J03_D4ncer
Enthusiast
If I enable center weighted metering using the quick control, will that override evaluative metering when I press the AF back button?
Waddizzle
By factory default, BBF should be independent of metering mode. If change metering mode elsewhere, then that is what mode will be used.
2 REPLIES 2
Waddizzle
Thank you.
