EOS R5 Quick Control Metering Setting
J03_D4ncer
Enthusiast
If I enable center weighted metering using the quick control, will that override evaluative metering when I press the AF back button?
Waddizzle
By factory default, BBF should be independent of metering mode. If change metering mode elsewhere, then that is what mode will be used.
2 REPLIES 2
Waddizzle
Thank you.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
