EOS R3 help, flashing gray box on screen/viewfinder
JamesPepper
Hi, so I accidentally hit a button on my canon EOS R3 and now I have this random flashing gray box on my screen/viewfinder. I know it has to do with auto focus as when I focus on something it disappears and when I’m in manual focus it disappears as well. It’s not spot focus as I can’t move it with the touch screen or the joystick. I have looked online I can’t find relevant help. Can someone tell me what this is and how to disable it
TW4
Hi James, I believe you've accidentally added a home point. You can check by activating your focus mode selection and press/hold the exposure compensation button until it beeps. This will disable the option.
Tony
6 REPLIES 6
rs-eos
Did you enable subject tracking perhaps? When in doubt of what you may have changed, you could return the camera back to default settings.
Ricky
FloridaDrafter
This is just a guess, but look in the AF 3 menu and see if "Preview AF" is enabled. If so, disable it and see if that removes the box.
Newton
TW4
Tony
I had the same issue and the above worked for me. Relevant section of the manual is here :
https://cam.start.canon/en/C010/manual/html/UG-04_AF-Drive_0060.html
I do love this camera but there's a lot to get to know as been out the game since my 40d
Does not remove the box
Waddizzle
I always use a Custom Shooting mode.  Any camera settings changes are not permanent unless I make them permanent.
Friends and Family
