EOS R10- is there a way to lock the exposure compensation
Nlemcoff
I have a Canon EOS R10 and it seems that, when I take a picture, I accidentally touch the screen and change the Exposure Compensation.
Is there a way to lock it?
jrhoffman75
You could try adjusting settings here:
3 REPLIES 3
jrhoffman75
Thanks!
p4pictures
One easy way to temporarily deactivate the LCD screen is to use the LOCK button on the camera and configure the multi-function lock to also lock the touch screen. The manual page here shows the quick control dial, joystick and lens control ring being locked, you need to add a check mark in the fourth space to lock the touch screen.
https://cam.start.canon/en/C006/manual/html/UG-09_Set-up_0230.html
One benefit of this approach over completely disabling the touch screen is that if you press the Q/SET or MENU button on the camera you can then use the touchscreen as normal.
Brian
